Author Topic: crankcase pressure  (Read 4186 times)
September 18, 2004, 05:42:39 pm
dieselpower
  • 177
crankcase pressure
« on: September 18, 2004, 05:42:39 pm »
hey,
i have high crankcase pressure when driving. removed the govenor and whenever i drive hard the dipstick pops outta the tube. is there anyway to vent crankcase pressure on the older 1.6td's?
thanks for the help
84 rabbit 1.6TD
because real cars don't have sparkplugs
Reply #1September 18, 2004, 06:54:58 pm
racer_x
  • 123
Re: crankcase pressure
« Reply #1 on: September 18, 2004, 06:54:58 pm »
There should be a vent hose from the valve cover that goes somewhere into the intake plumbing. Check for a clogged screen in the valve cover, or pinched or clogged vent hoses.
Reply #2September 19, 2004, 04:34:32 pm
dieselpower
  • 177
crankcase pressure
« Reply #2 on: September 19, 2004, 04:34:32 pm »
that opening is venting to the atmoshpere with a hose. I doubt there is much restriction in it but i'll check it out tonite.
thanks for the help
84 rabbit 1.6TD
Reply #3September 23, 2004, 08:00:40 pm
chrissev
  • 694
crankcase pressure
« Reply #3 on: September 23, 2004, 08:00:40 pm »
Quote from: "dieselpower"
thanks for the help
someone probably vented it then.  Usually it goes into the air intake.  The problem you might have is bad rings and excessive blow by, especially if you are running a turbo.  Might be time for a quickie glaze bust and new ring installation job.
Reply #4September 23, 2004, 08:26:41 pm
dieselpower
  • 177
crankcase pressure
« Reply #4 on: September 23, 2004, 08:26:41 pm »
ya i vented it. anyway theres a blockoff plate on the front of the engine, the gassers had a fitting there that went to the top vent. im thinking about drilling a hole in that and running a hose up to the top tube. does anyone see any problems with this?
84 rabbit 1.6TD
Reply #5September 24, 2004, 06:39:04 am
chrissev
  • 694
crankcase pressure
« Reply #5 on: September 24, 2004, 06:39:04 am »
Your car will smoke through the hood a lot, depending on where you put the vent.  Other than that I don't see a problem.  Diesels don't have any engine vaccuum so you won't be causing any problems with the vaccum system (there isn't one).  Take the plate off before you drill, you never know what might be behind it.
