Author Topic: no fuel from the Injector pump  (Read 3811 times)
August 05, 2006, 05:54:17 am
arfalberg
« on: August 05, 2006, 05:54:17 am »
The engine is not getting any fuel!!!
i checked timing and it was good, i checked the fuel cutoff and it showed 11.24 volts while the key was in run, and showed 10.something while in start position.
I am replacing the IP, could it be a faulty rebuild??
i removed one of the steel fuel lines while cranking to check for fuel and it is totally dry. i do have fuel in the tank and in the line all the way to the pump. in fact i even put some in the pump thinking it might need to be primed.
HELP! HELP! HELP!
Reply #1August 05, 2006, 06:21:49 am
Benjamin
  • 485
« Reply #1 on: August 05, 2006, 06:21:49 am »
it will take a time untill the pump finds diesel again.
Maybe there is comming air in the feul lines by the connections (maybe a forgotten copper O ring)
The best thing you can do with a diesel is pull it untill it starts (you dont need to hurt the starter)
i started my last engine up with just starting  :?  but, i used some propanegas (a little flame thrower) it works very good, the engine start, more rpm, the pump puming up diesel faster... you safe the starter
Greetz, Benjamin
EDIT
this is what i used, i put it on in the inlet (offcorse without a flame  :wink: )
http://media.weapons.be/deviant11/mokume5.jpg
SMOG alert, engine running again!
Must make +250hp
Reply #2August 05, 2006, 08:35:34 am
arfalberg
« Reply #2 on: August 05, 2006, 08:35:34 am »
got it running just had to prime the pump with fuel
used a 90 psi 3 gph 12 volt pump i had laying around to get it done.
thanks a bunch
Reply #3August 05, 2006, 11:13:51 am
  • 5104
« Reply #3 on: August 05, 2006, 11:13:51 am »
yeah, when i did my motor swap it took a bit of cranking to get it to start again,  the garage was all full of white smoke haha
Reply #4August 05, 2006, 03:16:36 pm
Benjamin
  • 485
« Reply #4 on: August 05, 2006, 03:16:36 pm »
yeah, the smoke is indescribable
Greetz, Benjamin
Must make +250hp
Reply #5August 05, 2006, 09:48:25 pm
935racer
« Reply #5 on: August 05, 2006, 09:48:25 pm »
A favorite picture of mine at approx 2am when we started malones franken motor for the first time after the complete rebuild. :P
Reply #6August 06, 2006, 04:23:21 pm
Benjamin
  • 485
« Reply #6 on: August 06, 2006, 04:23:21 pm »
thats the way it have to start  :D  8)
Gr8, isn't  :D
Greetz, Benjamin
Must make +250hp
Reply #7August 06, 2006, 08:31:05 pm
arfalberg
« Reply #7 on: August 06, 2006, 08:31:05 pm »
I would sure recommend using a fuel pump in line to pump fuel all through the IP then remove it and hook up the IP as normal it started in about 5 seconds and was running normal with no smoke within about 10 to 15 seconds.
my pump i used was a high pressure low volume pump but just about anything should work.
love the rebuilt IP...car starts with almost no cranking. before it would take 5 to 10 seconds before starting now it takes half a second or so.
Reply #8August 06, 2006, 10:09:14 pm
935racer
« Reply #8 on: August 06, 2006, 10:09:14 pm »
That car had a inline pump to the IP as well its just it was the first time it was started after a complete rebuild so there is some extra assembly lube being burnt there.
\AS for the inline pump, I reccomend throwing it back in, help extend the life of vane side of the pump, gives a little additional power, and makes bleeding the air out of the lines after something liek a injector swap a breeze.
