Author Topic: Wanted: Audi 5k TD  (Read 4028 times)
July 28, 2006, 03:12:54 pm
Turbinepowered
  • 1206
Wanted: Audi 5k TD
« on: July 28, 2006, 03:12:54 pm »
Alright, alright... my grand ambition of building a diesel Quantum Syncro has ground to a halt.
Finally got around to cleaning the engine block of the one that I got when I bought the car; turns out it's a CN engine, not the DE I thought I was getting.
CN: 65 bhp and not enough torque to move the heavy-arsed Syncro with it's AWD drivetrain. At least not with anything resembling alacrity. I'd just stick the turbo on it and fiddle with the injection pump/replace the injection pump to get the same power out of it, but I planned on tweaking it for some more power later on and I feel that having such things as the piston coolers would be a good idea.
Unless that's really the only bottom end difference between the two, those piston-cooling jets?
So, now I need to find myself a DE. I can offer a CN as a semi-core -slash- trade -slash- whatchawannacallit, but I can't put it in the car as it is now.
Reply #1July 28, 2006, 07:37:01 pm
therabbittree
  • 299
Wanted: Audi 5k TD
« Reply #1 on: July 28, 2006, 07:37:01 pm »
if its similar to a 1.6 then tahst about teh only difference the oil cooling jets ..maybe a funky prechamber..but you can turbo it or have amachine shop add the factory jets to yours...not a hard job at all..
soem ideas
later
Deo
\x/ hillfolk!
Reply #2July 28, 2006, 09:50:41 pm
itzdshtz
  • 94
Audi 5K TD
« Reply #2 on: July 28, 2006, 09:50:41 pm »
You can machine the block for oil jets, get some used oil jets from a gas 5 cyl.turbo engine( they are easy to get)
Notch the pistons for oil jet clearance.
Use the oil filter housing from the gas turbo too.(Use only the big oil filter, make a thick washer to block off the small oil filter opening. this will give you an oil feed line connection to your turbo plus it gives you a connection for an external oil cooler. It also has a build in thermostat that regulates the oil temp.)
You can run the turbo oil drain, that goes into the side of the block of a DE engine, into the oil pan like the 1.6 TD has.
The difference between the turbo cyl.head and the N/A cyl.head is that the exhaust valves are a bit better( 1.6 TD exhaust valves will fit) and that the pre chambers are made out of stainless steel instead of regular steel, ( try it, they are non magnetic on a turbo engine) but they will last OK in a turbo engine.
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
