Author Topic: Starter solenoid stuck  (Read 4602 times)
July 21, 2006, 06:40:50 pm
Doug
« on: July 21, 2006, 06:40:50 pm »
Anyone have a neat idea for getting this one working short of removal, disassembly and lube?  It's drawing current but not moving. Tried tapping it already with no results.
Reply #1July 21, 2006, 06:59:28 pm
« Reply #1 on: July 21, 2006, 06:59:28 pm »
Why don't you want to remove it? It's very easy
Reply #2July 21, 2006, 07:05:41 pm
Doug
« Reply #2 on: July 21, 2006, 07:05:41 pm »
You know that will be the ultimate solution but seeing as time is at a premium keeping all the rest of the equipment running maybe there is a quick fix .... just wishing...........
Reply #3July 21, 2006, 08:49:13 pm
Darkness_is_spreading
  • 288
Pull er out
« Reply #3 on: July 21, 2006, 08:49:13 pm »
it's a motor in the end, it prob is dirty and the solenoid just needs to be cleaned up if it drawing current,  I think starter solenoids are cheap to replace also....
Then coat everything in di-electric grease,  on the terminals and stuff to protect from corrosion,  Hell repaint the motor black and re-install in the morning
92 Jetta 1.6 T (Sleepin)
