Author Topic: are a2 clusters plug and play?  (Read 5172 times)
July 16, 2006, 01:49:54 pm
SMOKEYDUB
  • 630
« on: July 16, 2006, 01:49:54 pm »
i have a clock in my td and i have a cluster that has a tach in it and i noticed that there is a wire connected to the w terminal on the alternator. will the tach work if i plug it all in?
thanks
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1July 16, 2006, 07:45:44 pm
« Reply #1 on: July 16, 2006, 07:45:44 pm »
I know on the gas models there is a early and late mk2 cluster. I'm not sure about diesels, I'd have to check tomorrow. What years are they from?
Reply #2July 17, 2006, 06:15:04 pm
SMOKEYDUB
  • 630
« Reply #2 on: July 17, 2006, 06:15:04 pm »
both have the double cinnector soits 89 i belive
(courtesy of GILES)
Reply #3July 22, 2006, 04:13:50 am
Dennis Froelich
  • 258
« Reply #3 on: July 22, 2006, 04:13:50 am »
Yes it will. As long as the wire is red with a black stripe. My(now) TD Coupe had a clock also. I had the cluster from my donor car that had the diesel tach. I swapped the cluster and plugged it in and it worked. :shock:
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #4July 23, 2006, 01:46:54 pm
bustedfoxwagen
  • 31
    • http://www.wagenwerks.net
« Reply #4 on: July 23, 2006, 01:46:54 pm »
i did the same and the tach won't go bast 3000 you know what might be happening?
92 eco diesel jetta
Reply #5July 23, 2006, 04:51:23 pm
Dennis Froelich
  • 258
« Reply #5 on: July 23, 2006, 04:51:23 pm »
Could be the tach itself. My tach works great, goes to redline and beyond.
Don't really know for sure what could be wrong. Sorry.
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #6July 23, 2006, 06:16:38 pm
bustedfoxwagen
  • 31
« Reply #6 on: July 23, 2006, 06:16:38 pm »
that sucks! i just got it in yesterday and put it in today.... hope its not busted
92 eco diesel jetta
Reply #7July 25, 2006, 07:37:12 pm
SMOKEYDUB
  • 630
« Reply #7 on: July 25, 2006, 07:37:12 pm »
i did it and it works but only revvs to the gass gauge. :lol:
(courtesy of GILES)
Reply #8August 17, 2006, 01:52:00 pm
madmatt
  • 24
« Reply #8 on: August 17, 2006, 01:52:00 pm »
had problems with my t3 (vanagon)rev counter that was down to a bad connection in the engine the diesel clock seem to be more suseptable than the gas one,to test it i ran a wire from output w to the clock and it ran fine but by doing a resistance check on the origanal i traced it to a dry connection in the engine bay.
t3(vanagon)single cab, upright 1y
t3van aaz
t3 tdi
