Author Topic: 5 liter oil capacity.......how much circulates?  (Read 3823 times)
May 13, 2019, 07:18:37 pm
Spokerider
  • 195
« on: May 13, 2019, 07:18:37 pm »
If the aaz oil capacity is about 5 liters......how much volume is "in circulation" with the engine running?
 Anyone pondered this / figured it out?
 Thanks
Reply #1May 13, 2019, 09:32:38 pm
Dakotakid
  • 1240
Re: 5 liter oil capacity.......how much circulates?
« Reply #1 on: May 13, 2019, 09:32:38 pm »
Well,  it differs a bit if you are in zero gravity conditions.
Ponder THAT.
Reply #2May 14, 2019, 06:41:54 am
Spokerider
  • 195
« Reply #2 on: May 14, 2019, 06:41:54 am »
Smoke another fatty........ ::)
Reply #3May 14, 2019, 08:52:39 pm
  • 4553
« Reply #3 on: May 14, 2019, 08:52:39 pm »
Enough to keep the cam lobes from grinding down or the lifters from doing the same.  The lower crank bearings from sounding like a garbage disposal and the pistons from becoming attached to the sides of the cylinders.
What more do you need to know?
Reply #4May 18, 2019, 01:19:27 pm
Spokerider
  • 195
« Reply #4 on: May 18, 2019, 01:19:27 pm »
I'm modding the oil pan and pick up tube location. Making the pan deeper at the trans end, and shaving the pan under cyl 1 and 2.
 IF I know how much oil is in circulation with engine running, I'll know how much oil is in the pan. Then I'll know how to locate the pick up screen with possible addition of baffles, and not suck air on the steeps and on side hills.
 I will not be using the aaz plastic oil baffle.
 What you think........2 liters in circ?
Reply #5May 18, 2019, 07:28:41 pm
  • 4553
« Reply #5 on: May 18, 2019, 07:28:41 pm »
Mod the oil pan?  OK if you have to.
I would think 2 liters is a bit much for all that is circulation.  Maybe counting the head catching some and then the drain down.
I would suspect that if you keep the pickup tube the same distance from the bottom of the pan you would not have any problems.  The volume in there would be higher at the one end if the capacity was the same.  So do you think you would have problems with the crank splashing into it and creating flow disruptions?
More oil in the same pan would be similar and don't we get warnings not to overfill past the full mark by more than 1/2 a liter.
Just some thoughts.  Keep us up to date on this.
Reply #6May 19, 2019, 08:39:38 am
Spokerider
  • 195
« Reply #6 on: May 19, 2019, 08:39:38 am »
Reply #7May 21, 2019, 07:47:17 pm
  • 4553
« Reply #7 on: May 21, 2019, 07:47:17 pm »
Nice cuts there fella.  Not done with the saws-all I own that is for sure.
Reply #8May 27, 2019, 08:28:29 pm
Trunganh1131
  • 5
« Reply #8 on: May 27, 2019, 08:28:29 pm »
Very nice cut, Fella
