Author Topic: anyone have a hitch on a mkIII?  (Read 4423 times)
July 12, 2006, 12:05:21 pm
BlackTieTD
  • 1512
« on: July 12, 2006, 12:05:21 pm »
i'd like to get a hitch for my '94 jetta. i don't know the recommended max. towing capacity of the vehicle off-hand but i'd like a class 2 hitch that is capable of 3500Ibs.
does anyone have something like this on their mkIII? is there a bolt on solution or should i get a hitch shop to fab this up and weld it on?
i will be towing cars and trailers with car parts... nothing over 3500Ibs but close. i figure when the transmission lets go i'll know what the limit is.
Reply #1July 12, 2006, 07:35:27 pm
QuickTD
  • 1156
« Reply #1 on: July 12, 2006, 07:35:27 pm »
I have one on my jetta. I built it myself because I wanted a 1-1/4" receiver and not the 2 x 5/8" flat bar type. There is only sheet metal behind the axle, so you won't be welding much there... I bolted mine through the inner surface of the 2 rear sheet metal "frame rails". Three 3/8" bolts per side with large fender washers have held it for a couple of years of heavy use, sometimes towing more than would be considered prudent...
  MacGyver has a bolt-on "hidden hitch" brand hitch. He likes mine better as it's far more hidden... I've looked over his hidden hitch and it appears to be a well constructed unit. It has the flat bar type receiver, not sure of the rating.
Reply #2July 28, 2006, 09:05:42 am
bhtooefr
  • 305
    • http://my.opera.com/bhtooefr
« Reply #2 on: July 28, 2006, 09:05:42 am »
Get a Bosal towbar.
They're hard to get in North America, but they're the OEM solution, and when you don't have the swan-neck receiver in, you don't know it's there.
1986 Volkswagen Golf | 1.6L NA diesel | 5spd manual | Deep Cosmic Blue (LE5C) | aack, it's a parts car, now, too!
1992 Mazda Miata | 1.6L DOHC gasser | 5spd manual | Classic Red (SU)
Reply #3August 26, 2006, 06:25:44 pm
1.9blues
« Reply #3 on: August 26, 2006, 06:25:44 pm »
i have OEM hitch on 94 Golf.... like to give it away
