Author Topic: new rear springs  (Read 7613 times)
July 07, 2006, 06:09:54 pm
mainer
  • 126
new rear springs
« on: July 07, 2006, 06:09:54 pm »
Everyone here with an a2 knows what I'm talking about. You put 3 or 4 people in your it, or u put some stuff in the trunk. And your car looks like it's takin a ***, it goes down the road with the front wheels harldy on the ground. Well she no longer squats in the rear. Someone on here put longer springs out of a passet in their car. So I got a set of b3 passet springs on vortex for 36 bucks shipped. I put them in tonight. I wasn't expecting it to be so high but I like it.
Any sugestions on what to do to lift up the front??
Before
After
Let me know what you thing. I know most of you lower your cars, and that is my plan with the a1 I have. The a2 is the car I have to use every day now, and with 3 people it sat way to low to use, so I fixed the problem.
Coop
_________________
Love Stories Forum
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #1July 08, 2006, 11:00:30 pm
hillfolk'r
  • 1532
new rear springs
« Reply #1 on: July 08, 2006, 11:00:30 pm »
i got those "cargo springs" from parts place for my a2(it was my dads,so i know the history)
as it is,this a2 always sat real low ,even up front,but after 10 years,it did sag some in the back,now,its slightly raked+can carry weight with the cargo springs,my dad said (thumbs up)
i like the rake,id like to do this to my rabbit for the drags(id make upa set of struts i could swap in before id  go to the track
but it does look a little too much probablyfor most folks,but us hillfolks like crazy stuff
Throttle cables ftw
Reply #2July 09, 2006, 05:25:56 am
Patrick
  • 1034
new rear springs
« Reply #2 on: July 09, 2006, 05:25:56 am »
I'm the guy that did it, mine looks about the same. If you decide it's too much, take it apart again and cut some off the top of the spring. Try a 1/2 coil at a time. it will still be stiffer than stock even at the factory hieght because it's a heavier diameter wire.
As fr the front, a cheap "quick fix" is a set of the twist in rubber spring boosters you can get a Canadian tire. I'd bet there's another spring that will do the same to the front you just did to the back, but it might be tough to find. There's a lot more options for the front from the factory than there ever was for the back! Check it out, different fronts depending on 2 door, 4 door, air conditioning, automatic, etc. You might find  a factory mk 2 spring that will do what you want.
Reply #3July 09, 2006, 12:27:02 pm
mainer
  • 126
new rear springs
« Reply #3 on: July 09, 2006, 12:27:02 pm »
I like the height of the back how it is. I might have the car sold, so I wont be lifting the front. But if it isn't sold I will deffentaly look into lifting up the front.
I did notice going down hills around corners the back end wants to kick out if your not carefull.
Cooper
_________________
roll a joint
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #4July 09, 2006, 03:12:41 pm
MaxHedrm
  • 114
    • blog
new rear springs
« Reply #4 on: July 09, 2006, 03:12:41 pm »
Quote from: mainer
I would imagine so. For a few reasons. You've shifted weight off the rear which would reduce traction, plus you have increased the spring rate making it bounce a bit more when unloaded.
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #5July 09, 2006, 08:40:33 pm
hillfolk'r
  • 1532
new rear springs
« Reply #5 on: July 09, 2006, 08:40:33 pm »
rabbittrees ol demon car looked like that,yea a little tail happy,but that can be fun too
woah dude,look at my posts,666  posts
ill stop tonite,lol
aagh
Throttle cables ftw
Reply #6July 09, 2006, 09:44:09 pm
jackbombay
  • 599
new rear springs
« Reply #6 on: July 09, 2006, 09:44:09 pm »
Quote from: "hillfolk'r"
   Here is an Avatar I made for you!
Reply #7July 14, 2006, 12:44:17 pm
moosiah
  • 106
new rear springs
« Reply #7 on: July 14, 2006, 12:44:17 pm »
are those 14" riims on there???  I jacked up my rabbit w 14" audi  rollas w 24" tires and rabbit cabrio springs...... Not really for off roading , more for the trips up an' down dirt roads..... :lol:  There are so many potholes in SF  streets that I may as well be driving on dirt fire roads!!!!  :lol:
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #8July 19, 2006, 07:26:33 pm
addautomotive
new rear springs
« Reply #8 on: July 19, 2006, 07:26:33 pm »
Make sure to aim your headlights!
FWIW, I cured my sagging arse by adding an extra set of lower spring perches when I put in new struts. In my old A2 Jetta, I had 3 sets of perches... was a bit tough to bolt back together but it made the rear stiffer without adding too much height.
Reply #9July 27, 2006, 11:48:29 pm
  • 2932
springs
« Reply #9 on: July 27, 2006, 11:48:29 pm »
I put new rear boge shocks on the Rabbit but 2500 miles later they were junk.
 I think it's because the old springs were weak and the rear sagged too low when loaded with a few cans (20 gallons) of vegetable oil:
 So I put new shocks and some Audi 4000 springs (and lower seats) on the Fatmobile:
 This picture was taken on the way back from 10,000 lakes Festival so I was only carrying about 4 gallons of vegy but the car was packed with camping gear.
 I think centurion gave me the idea. It rides great especially when loaded. Not a stiff ride. Rides a little high when empty :D .
 Oh yeah, being up so high, it leaned real bad when turning so I put the 16V, rear anti-sway bar on. It just dives into the corners now.
Reply #10July 28, 2006, 07:53:34 am
MacGyver
  • 245
new rear springs
« Reply #10 on: July 28, 2006, 07:53:34 am »
Fatmobile: Audi 4000 springs just in the rear or all around? Did you do anything to the front?
Reply #11July 28, 2006, 11:31:09 pm
  • 2932
springs
« Reply #11 on: July 28, 2006, 11:31:09 pm »
I just swapped the rear springs.
 The front struts and springs are from my pickup.
Reply #12July 29, 2006, 09:30:03 am
Patrick
  • 1034
new rear springs
« Reply #12 on: July 29, 2006, 09:30:03 am »
The green 92 (1.9TD 5 speed) has '93 passat springs in the back with about 1/2 coil cut off, about 300 lbs in the trunk, 15" BBS with 195/60R 15's. Will probably cut another 1/2 coil off next time I have something apart.
The grey 92 (1.6TD 5 speed) has chevette front springs in the back, factory bottlecaps with 185/60R14's.
Ride on the grey car is MUCH nicer, but the green one corners better and is a LOT more fun to drive!
