Author Topic: i need a clutch pushrod for a 5 speed  (Read 4947 times)
July 05, 2006, 01:02:50 pm
Master ACiD
  • 328
« on: July 05, 2006, 01:02:50 pm »
my pushrod is worn down pretty good. i cant disengage the clutch anymore. im looking for a good used or new pushrod and a clutch release plate as well.
thanks.
Reply #1July 05, 2006, 03:31:55 pm
SMOKEYDUB
  • 630
« Reply #1 on: July 05, 2006, 03:31:55 pm »
are you sure its worn? because on vws its pretty famous of a lever inside the trans to crack and not work anymore. the lever is located behind the green cover on the side of the transmission. the little lever almost looks like a 9 you cant miss it.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2July 05, 2006, 07:19:03 pm
Master ACiD
  • 328
« Reply #2 on: July 05, 2006, 07:19:03 pm »
so, i pull the green cover and look for a lever in the shape of a 9? ill give it a try tomorrow and post the results.
thanks.
Reply #3July 05, 2006, 08:02:41 pm
SMOKEYDUB
  • 630
« Reply #3 on: July 05, 2006, 08:02:41 pm »
its hard to see the crack so look careful
(courtesy of GILES)
Reply #4July 06, 2006, 10:32:58 am
Kudagra
  • 738
    • www.no-coast.com
« Reply #4 on: July 06, 2006, 10:32:58 am »
still need the pushrod?
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #5July 07, 2006, 11:42:45 am
Master ACiD
  • 328
« Reply #5 on: July 07, 2006, 11:42:45 am »
i looked at the rocker arm that is in the shape of a "9" and it looks good. i noticed the 9 is on a splined shaft. i took and pit the 9 1 click over on the splines so that theres less gap and now the clutch *seems* to work fine.
sence the release bearing inside the trans is accessable via that green cover, is it safe to assume that the pushrod is as well? if so, then i could just install the trans as it is, and if i find that i still need a pushrod and release bearing, can i change those 2 items out while the trans is still attached to the engine and in the car?
thanks.
