Author Topic: and this works even better  (Read 4972 times)
June 30, 2006, 10:34:24 pm
hillfolk'r
  • 1532
« on: June 30, 2006, 10:34:24 pm »
swapped this in place of my single jet,i tested the flow it was about the same if not a little more,but i restrict it upstream
theres holes 180 degrees on the other side
Throttle cables ftw
Reply #1July 01, 2006, 04:44:14 am
Benjamin
  • 485
« Reply #1 on: July 01, 2006, 04:44:14 am »
This is for the WI?
Greetz, Benjamin
Must make +250hp
Reply #2July 01, 2006, 10:30:57 am
hillfolk'r
  • 1532
« Reply #2 on: July 01, 2006, 10:30:57 am »
yes sir,,,,if i have time this weekend,ill try to hook it up to a spray can so you can see it spray
i got them from my dad,and i think they are used for a fuel primer in an small airplanes,it threads into the intake,and you have a primer bulb to push fuel in
you  should be able to find them at
aircraftspruce.com
not a link,cut+paste the link
using aircraft parts on your car rules!!!
Throttle cables ftw
