Author Topic: Maybe dumb question? :o  (Read 4149 times)
June 30, 2006, 07:17:23 pm
VW Scully
  • 245
    • Not Quite Tom Riddle's Diary
« on: June 30, 2006, 07:17:23 pm »
Hi everyone;
Just a quick question; where is the fuel pump located in a Rabbit Diesel!?!?!  :oops:
Thanks!  :D
Tara aka VW Scully
**1981 Rabbit Diesel L, Biodiesel driven: 'the Bio-Bunny' **
Advocate for Young Adult Cancer Research & Support: I'm too Young for This!!
http://www.i2y.com
Reply #1June 30, 2006, 08:50:56 pm
VW Scully
  • 245
« Reply #1 on: June 30, 2006, 08:50:56 pm »
oh DUH! :oops: I thought there was a separate pump from the tank (like in a gasser Rabbit).  :?:
Thanks  :D
Tara aka VW Scully
http://www.i2y.com
Reply #2June 30, 2006, 09:25:53 pm
coke
  • 254
« Reply #2 on: June 30, 2006, 09:25:53 pm »
The fuel injection pump is two pumps in one. A vein pump to draw the fuel from the tank and the high pressure distributor pump to distribute precise fuel amounts to the injectors.
It eliminates the need for an auxillary pump, therefore, only having one. The only problem is when the veins dont work anymore, most people have to add an aftermarket one on.
Reply #3June 30, 2006, 10:48:30 pm
moosiah
  • 106
lift pump
« Reply #3 on: June 30, 2006, 10:48:30 pm »
Hi there ,    The vane pump is also the source of presure that opperates the injection timing advance mecanizum thingy......... :wink:
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #4July 02, 2006, 08:10:11 pm
hillfolk'r
  • 1532
« Reply #4 on: July 02, 2006, 08:10:11 pm »
you can add a "lift pump" back where the gasser pump would reside,it helps the vane pump in the injection pump out some,and you may/will notice a power/throttle response improvement :D
Throttle cables ftw
Reply #5July 03, 2006, 12:39:02 am
935racer
Re: lift pump
« Reply #5 on: July 03, 2006, 12:39:02 am »
Quote from: moosiah
Well yeah the fuel pressure determines the injection timing advance, once the pump builds up a certain pressure (pressure from the vanes) the pressure control valve regulates fuel pressure in the the inner chamber in proportion to RPM. The extra fuel than pushes against the sprung timing piston and pushes the timing plunger over which moves the roller rings and rollers, thus advancing the dynamic timing to help battle INJECTION and IGNITION lag. :wink:
