Illegal in the U.S. good thing I live in Canada! If you have a leaky system, then by all means, installing the HC refrigerant is pretty dangerous. I don't have ANY leaks, and I've been using the HC refrigerant for over a month now with no problems, and I'm extremely content with the performance + temp of my system. There appears to be no pressure drop on my system as well. I have used a can of the Duracool system seal and that should keep the joints nice and sealed tight.
I don't like the EPA. They give our diesel cars a really bad MPG reading. Probably because they don't know how to drive. As for cutting up HC refrigerant, they can bite me. Instead of trying to encourage SAFE use, they merely oppose its use and see it as a threat.
HC refrigerant has a auto-ignition point than R134A (1635F!!! Your turbo will melt before this stuff will explode). Plus the fact that you only need 40% of the amount of R134A and 35% of CFC-12 to cool your system makes it extremely appealing, doesn't it? After all, you're going to see less pressure in your entire system (mostly the high side), which will mean it will be less likely to have leaks! Less head pressure, and also less head temperatures mean that your compressor isn't going to be working as hard, and as such will have extended life (less likelyhood to break down due to overheating).
So as long as your system is good and sealed, I can't see anything wrong with it. If you go with R134A you need to change all your seals btw, or it won't last more than a year. (unless you use a sealer... maybe).
If I ever explode because I have approx 12 oz of propane in my car, I will make sure to make one last trip to my pc and post on here with my results. :lol: (and that is IF I don't sniff it out before it ignites... hint: roll down windows)
**no I'm not a salesman for duracool, I'm just pro-environment, pro savings, and pro-health; I'm also into colloidal silver if anyones interested. This is a nice read
http://www.hychill.com.au/pdf/facts.pdf haha supposedly some car fires were reported, but they were charged with R12 and R134A... not the HC... I'm beginning to believe that the EPA is being payed off :x
edit: read the duracool faq
http://www.duracool.com/Duracool/faqs.html
