Author Topic: clutch bleeding schedule  (Read 4133 times)
June 25, 2006, 06:52:00 pm
prysm
  • 41
    • http://www.fernski.com
« on: June 25, 2006, 06:52:00 pm »
I am not sure if you guys have hydraulic clutch, But if you do...
How many times do you bleed it in a year? It seems I need to bleed my pickups clutch every 6 months or I risk the chance of losing my clutch in the freeway.
Any inputs from the experts??
,Fernan
mazda B2200 2.2L R2 diesel
Reply #1June 25, 2006, 11:01:37 pm
LeeG
  • 401
« Reply #1 on: June 25, 2006, 11:01:37 pm »
It shouldnt need to be bled ever, so it probably needs a new seal.  After a few million shifts the edges are rounded off and it will start to suck air on release or leak down.
I had a truck, the slave was aluminum with a slightly pitted bore.  replacement was $$$ from the stealer.  But a few cents for a new seal with fresh new edges every couple years kept it going for a looong time.  (This slave happened to take a regular brake cup so that was cheap)
'97 Passat TDI
Reply #2June 26, 2006, 06:09:00 am
prysm
  • 41
« Reply #2 on: June 26, 2006, 06:09:00 am »
thanks for the reply
I already rebuilt the slave cylinder twice and the fluid gets dirty very quickly and it will start loosing fluid. The last time I just filled it up again which was a mistake because After a few days the the cylinder lost pressure and started leaking.
I guess the slave needs to be replaced.
,Fernan
