Author Topic: yet another head question  (Read 3237 times)
June 23, 2006, 11:07:48 pm
deadcaddy
  • 15
« on: June 23, 2006, 11:07:48 pm »
OK guys, help me out here- as I finally got back to my head gasket changeout, I am cleaning/degreasing and inspecting my parts and I notice there are small cracks between the valves- I read somehwere else that this is pretty common- what does this mean?  Is my head trashed, what will it affect, if anything?  What, if anything should I do about it? HELP
if you can't be a good example, try being a horrible warning
Reply #1June 26, 2006, 06:12:06 am
Justin
  • 455
« Reply #1 on: June 26, 2006, 06:12:06 am »
if you cannot get your thumbnail in it then use the head as is, if you can get your tumbnail in it then i would worry and take it to the machine shop have it welded up and touch up your valves
later
Justin
www.archeryprostaffmi.com
