Author Topic: Crank Mod  (Read 4072 times)
June 21, 2006, 08:18:47 pm
Kudagra
  • 738
    • www.no-coast.com
Crank Mod
« on: June 21, 2006, 08:18:47 pm »
Ok I have a few 1.6td and I keep hearing about the 1.9 crank Mod. I know this fixes a poor engineering job on the crank snout...but ya got any pictures and how to do it? Or maybe a link?
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #1June 22, 2006, 07:00:31 am
QuickTD
  • 1156
Crank Mod
« Reply #1 on: June 22, 2006, 07:00:31 am »
The pictures in my "how to" post ceased to work awhile ago. I'm not sure I have the energy to put them up again...
http://vwdiesel.net/phpBB/viewtopic.php?p=20725
 If you have a 1.6 you don't need to worry about this issue anyway. If you have a 1.9, the fix involves pulling the crank and welding the old keyway and the worn end of the crank then machining it down to accept a TDI crank pulley. The TDI pulley has a flat instead of a key and has been more reliable.
Edit - Repaired the images in the link, enjoy...
Reply #2June 22, 2006, 07:57:09 pm
Kudagra
  • 738
    • www.no-coast.com
Crank Mod
« Reply #2 on: June 22, 2006, 07:57:09 pm »
I only ask because of the 2 engines i have BOTH have a little 1/2 keyway space on the nose of the crank and there IS wear on one side of that keyway where it looks hammered. Just wondering if I should worry.
