Downpipe arrived & installed
Topic: Downpipe arrived & installed (Read 3555 times)
June 21, 2006, 03:00:05 pm
stewardc
June 21, 2006, 03:00:05 pm »
Thanks for the downpipe, Dave. I like the flange for exhaust system connection. Great work....installation tomorrow.
June 21, 2006, 04:09:53 pm
June 21, 2006, 04:09:53 pm »
that is one beautiful downpipe
June 22, 2006, 03:46:28 am
Rat407
Authorized Vendor
June 22, 2006, 03:46:28 am »
That is one sweet down pipe.
One question, how is it going to be braced to the engine? Wouldn't all that movement of the engine even with the flex pipe put a good bit of stress on the turbo flange?
I braced mine to the factory bracket on the exhaust manifold. I just used a 2.5" muffler clamp and modified the bracket to work with the clamp.
One other item of interest. Since I'm still a newby, how long does the flex pipes last? Is it a concern for replacement? If so then maybe it should be attatched to the downpipe via a flange for easy replacement??? So far my flex is in great shape but I only have 15k miles on it.
One thing is for sure, adding a 2.5 inch downpipe will wake up the 1.6L
AMS
OIL
Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta ECO TD
June 23, 2006, 04:19:45 am
stewardc
June 23, 2006, 04:19:45 am »
Installed it yesterday and was amazed at the difference in performace with little or no change in sound. I used a 2.25" pipe with a Magnaflow muffler and stainless tip. I may have to move the fuel filter as it is very close now.
June 24, 2006, 07:21:05 am
mk1vdub
June 24, 2006, 07:21:05 am »
that does look very nice, I could really do with one of them :roll:
would you be able to take some more pics of it fitted, like down around the gear linkage
1983 mk1 golf GTD
1980 mk1 scirocco Gli, in bits, in the garage, awaiting full restoration
June 24, 2006, 07:25:14 am
mk1vdub
June 24, 2006, 07:25:14 am »
oh and by the way has anyone from the UK bought one?
how much did it work out with shipping, customs charges, etc?
ta
1983 mk1 golf GTD
June 24, 2006, 11:24:30 pm
hillfolk'r
June 24, 2006, 11:24:30 pm »
when i make my "custom downpipes" i weld an extra tab on the dp,so i can use the orig block+tranny brace like the old dual dp has on it,my first one i did without the braces,it lasted less than a year before it cracked,but since ive been usin the braces,i havent had a prob......
Throttle cables ftw
June 25, 2006, 09:17:08 am
Rat407
Authorized Vendor
June 25, 2006, 09:17:08 am »
Stewardc, Where can I find a cam cover like that? I have been looking for one but not having much luck.
Thanks
AMS
OIL
1991 Jetta ECO TD
June 25, 2006, 10:09:18 am
stewardc
June 25, 2006, 10:09:18 am »
It's an aluminum G60 Corrado cover that I had powdercoated. They are available from the dealer for megabucks, but I found one on the Vortex forum.
