Author Topic: Needed: parts to fix 1.9 TD sheared crank gear  (Read 3773 times)
June 21, 2006, 02:15:21 pm
ibmserf
  • 30
« on: June 21, 2006, 02:15:21 pm »
If anyone can help I need the following:  crankshaft, a crankshaft timing pulley, some valves/lifters, gaskets crank seals, head bolts, rod and main bolts and lower end bearings- this is what I have been told I need.  If anyone can think of anything else it would be much appreciated.
1.9L TD Jetta
