Author Topic: only getting pressure reading on gauge  (Read 4636 times)
June 20, 2006, 08:49:17 pm
superman293
  • 93
« on: June 20, 2006, 08:49:17 pm »
I just got done installing a pressure/vacume gauge in my 2000 TDI, I installed a fitting in the 3" soft pipe that is clamped to the intake. im only getting a pressure reading, no vacume, I know that the pressure does work on the gauge, do i need to "T" into a different place?
thanks
Reply #1June 20, 2006, 10:28:46 pm
vwmike
  • Authorized Vendor
  • 1158
« Reply #1 on: June 20, 2006, 10:28:46 pm »
VW diesels don't have throttle bodies and without a throttle body you're not going to see any vacuum.
Reply #2June 21, 2006, 01:54:53 pm
superman293
  • 93
« Reply #2 on: June 21, 2006, 01:54:53 pm »
so there is no way to get a vacume reading?
thanks
Reply #3June 21, 2006, 02:18:16 pm
vwmike
  • Authorized Vendor
  • 1158
« Reply #3 on: June 21, 2006, 02:18:16 pm »
not on that engine.
Reply #4June 21, 2006, 09:58:51 pm
hillfolk'r
  • 1532
« Reply #4 on: June 21, 2006, 09:58:51 pm »
get a boost guage that reads psi only,ya dont need a vacuum scale
Throttle cables ftw
Reply #5July 04, 2006, 08:11:51 pm
therabbittree
  • 299
« Reply #5 on: July 04, 2006, 08:11:51 pm »
yup diesels don't have vacuum ..like a gasser..i guess you could try to tee in to the vaccum pump ..ha ..but it would be a constant reading as its a pump ..not engine load supplying the vacuum
later
Deo
\x/ hillfolk!
Reply #6July 04, 2006, 08:31:06 pm
hillfolk'r
  • 1532
« Reply #6 on: July 04, 2006, 08:31:06 pm »
ive got an inches of water vacuum guage from a big truck that you could put in the pipe from the filter to the turbo,itll tell ya when yer air filter is clogged,its a 2 inch guage,reads to 40 inches,i used to have one  in my rabbit truck,with a k+n style filter,i never saw it move :D
Throttle cables ftw
Reply #7July 15, 2006, 01:38:12 am
madmatt
  • 24
« Reply #7 on: July 15, 2006, 01:38:12 am »
if you do see a vacuum you need to look at the intake to see where the restriction is.
t3(vanagon)single cab, upright 1y
t3van aaz
t3 tdi
