Author Topic: ALH TDI Block (bare)  (Read 6566 times)
June 19, 2006, 10:11:55 am
Mikeyworks
  • 260
    • http://www28.brinkster.com/mikeyworks/
« on: June 19, 2006, 10:11:55 am »
I have an ALH TDI Block that I want to get out of my garage.
Virtually everything has been taken off/out of it so right now it's a bare block.
I will be taking offers, but just to start the haggling I am asking $200 obo.
I am in Havre de Grace, MD (21078) if you want to think about shipping.  I can ship it and get you an estimate per your request.
Mikey
Reply #1June 28, 2006, 06:02:57 pm
renny10n
  • 25
« Reply #1 on: June 28, 2006, 06:02:57 pm »
Howzit going Mikey!
By any chance,  do you still have that alum. water flange that mounts to the back of the head?    I believe you listed it as a "Coolant Junction w/ Coolant Glow Plug Section"(pt.#038-121-133A/028-121-145B).
If so, please give me a jingle.  I have a plastic one, but looking for the alum. one for a project I'm working on.
Thanx! :D      ....renny
aloha!   ....renny
1987 Suzuki Samurai(soon to be repowered with A4/ALH 2001 TDI mated to Toyota truck xmsn/t-case.
Reply #2June 28, 2006, 06:43:09 pm
Mikeyworks
  • 260
« Reply #2 on: June 28, 2006, 06:43:09 pm »
Renny,
I will check on that flange for you.  I have to figure out which box it's in!!!!
Mikey
Reply #3June 28, 2006, 07:05:46 pm
Mikeyworks
  • 260
« Reply #3 on: June 28, 2006, 07:05:46 pm »
Sorry Renny, I looked back through my invoices and that sold about a year ago...need anything else?  I have a bunch of parts.  Let me know what you need and I will see what I have to help.
Mikey
Reply #4July 02, 2006, 10:57:53 pm
renny10n
  • 25
« Reply #4 on: July 02, 2006, 10:57:53 pm »
MIkey,
Thanks & bummer!   It's always my case, a day late, etc.   Anyways,  do you recall exactly what year & model that particular water flange came off of- greatly appreciated! :)
....renny
aloha!   ....renny
Reply #5July 02, 2006, 11:06:38 pm
nkb
  • 154
« Reply #5 on: July 02, 2006, 11:06:38 pm »
my 98 ahu has that fitting, three glow plugs in it? my engine is from a 1998 jetta tdi 5speed. hope this helps..
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
Reply #6July 03, 2006, 12:09:03 am
renny10n
  • 25
« Reply #6 on: July 03, 2006, 12:09:03 am »
Thanks nkb! :D
Is water flange on your '98 AHU Jetta a two piece alum. job(glow plug section bolted to water flange?) that's bolted to the back of the head?
My ALH/TDI engine came out of a 2001 beetle & is ready to be transplanted into my Suzuki Samurai.  However,  the stock plastic water flange kinda of protrudes out too far,  so I would have to space the engine to much forward to my liking!  With the alum. one,  I notice the glow plug section can be unbolted & by using a flat plate/cover,  it would shorten it up quite a bit & then the engine can sit closer to the fire wall.   Plus since I only need the water outlet spicot,  the other port can be welded shut.
aloha!   ....renny
Reply #7July 03, 2006, 12:30:02 am
nkb
  • 154
« Reply #7 on: July 03, 2006, 12:30:02 am »
i thought it was one piece but i can take a look later on(430am its getting late heh) one thing you could do is modify your firewall to clear the fiting? like cut a section out and fab a piece that clears the pipe?
2004 Jetta TDI
1986 S-10 LT1
