Author Topic: What kind of hp and tq do you think I am running?  (Read 4607 times)
September 07, 2004, 12:24:53 pm
SMOKEYDUB
  • 630
« on: September 07, 2004, 12:24:53 pm »
I m sorry for posting alot of posts.. but I am a curious kid (18). I was wondering if I was around 120hp. The things i have done to my td....
89 mazda 626 intercooler
the screwdriver trick
and I am running 22 psi
I can beat 1.8l vw motor and a 1.9 tdi so hopefully around 110 just curious thanks for the help
Jeff :twisted:
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1September 07, 2004, 12:26:04 pm
SMOKEYDUB
  • 630
« Reply #1 on: September 07, 2004, 12:26:04 pm »
o ya and I ran a 17.2 with full interior
thanks
(courtesy of GILES)
Reply #2September 07, 2004, 01:12:40 pm
VWRacer
  • 649
« Reply #2 on: September 07, 2004, 01:12:40 pm »
The formula for calculating hp from ET is: hp = weight/(ET/5.825)^3
Assuming 2550 for the weight of your '86 Jetta with you in it...I get 99 hp.
That figure may be possible with the mods you list.
Stan
C-Sports Racer
Reply #3September 07, 2004, 08:13:52 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #3 on: September 07, 2004, 08:13:52 pm »
i've got a gtech.... :wink:
Reply #4September 08, 2004, 05:41:58 am
VWRacer
  • 649
« Reply #4 on: September 08, 2004, 05:41:58 am »
Doc, did you get the "Pro" G-Tech like Jakes? :idea:
BTW Smokey, the ET method is not highly accurate with turbo cars, especially FWD ones. If you know the MPH at the end of the 17.2 sec run you can get a more accurate hp estimate using this formula:
hp = weight * (speed/234)^3
Give that a try and let us know. Or tell me your speed and I'll do it for you. :D
Stan
Stan
C-Sports Racer
Reply #5September 08, 2004, 03:22:48 pm
andy2
« Reply #5 on: September 08, 2004, 03:22:48 pm »
by the sounds of it I've got to be in that hp range too,I definitly need to G-tech mine also :(
