Author Topic: Oxygen injection?  (Read 4980 times)
June 15, 2006, 01:43:18 pm
tylernt
  • 344
Oxygen injection?
« on: June 15, 2006, 01:43:18 pm »
So if your injection pump can supply more than enough fuel and you're running out of oxygen to sustain the combustion process, why not hook up an oxygen tank and shoot some into the intake manifold?
I did find one only reference to 18-wheeler diesels running oxygen injection back in the 60s or 70s, but that was it. Was it because it was too dangerous, or the Federal DOT created regulations against it or something?
I realize NOS is much safer, I'm just curious why straight O2 isn't used.
Reply #1June 15, 2006, 02:24:22 pm
hoyt
  • 22
    • http://www.zoiedog.com/hoyt
Oxygen injection?
« Reply #1 on: June 15, 2006, 02:24:22 pm »
One reason is most likely because pure oxygen auto-ignites in the
presents of petroleum products.
--John
  '82 Diesel Vanagon
Reply #2June 15, 2006, 02:26:50 pm
  • 1156
    • Malone Tuning Ltd.
Oxygen injection?
« Reply #2 on: June 15, 2006, 02:26:50 pm »
Congratulations, you just invented a cutting torch! :)
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #3June 15, 2006, 02:37:45 pm
vwmike
  • 1158
Oxygen injection?
« Reply #3 on: June 15, 2006, 02:37:45 pm »
The idea behind using nitrous oxide in the first place is that the nitrogen acts as a buffer to slow the release of the oxygen.
Reply #4July 03, 2006, 11:04:16 pm
Kantdrive55
  • 65
    • http://www.dieselperformance.com
Oxygen injection?
« Reply #4 on: July 03, 2006, 11:04:16 pm »
Nitrous is basically turbo in a bottle.  I work for a large performance diesel manufacturer and we specialize in the pickups, but I just purchased a TD Jetta 93 so here I am.  We have seens gains of over 250 hp with a dual stage dry nitrous system.  Basically the more fuel you have the more nos you can use.  We saw drops of around 250deg in egts as well.  Nos is expensive though and it doesnt last a long time.  Water/Methanol kits are becoming increasingly popular as well.  The water is cooling the combustion charge and the methanol is burning as fuel to create power.  This is a much less expensive option as well as you are using regular windshield washer fluid.  On the pickups we see gains of around 70hp.  I would expect to see in the neighborhood of 15-25hp on the vws.  Snow Performance makes a great kit.
  The only concern I guess would be cylinder pressures and if the head gaskets and head bolts would take the pressure????  Newbie to the VW Diesel,  so maybe someone can help me out on this.
1993 TD Jetta
Cold air intake,pump tweaked,2.5" exhaust and more to come.
Reply #5July 04, 2006, 09:34:02 am
DVST8R
  • 535
Oxygen injection?
« Reply #5 on: July 04, 2006, 09:34:02 am »
Quote from: "Kantdrive55"
Who?
BD, Piers(ADP) or Dtt?
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #6July 06, 2006, 09:03:55 pm
Kantdrive55
  • 65
Oxygen injection?
« Reply #6 on: July 06, 2006, 09:03:55 pm »
I work for BD.  Been in sales/tech there for 5 years.  My name is Pat.
1993 TD Jetta
Reply #7July 06, 2006, 09:08:17 pm
Kantdrive55
  • 65
Oxygen injection?
« Reply #7 on: July 06, 2006, 09:08:17 pm »
Quote from: DVST8R
Quote from: Kantdrive55
Who?
Dont forget you have to call Piers, PDR Diesel now :lol:
1993 TD Jetta
Reply #8July 06, 2006, 09:47:52 pm
greggearhead
  • 153
Oxygen injection?
« Reply #8 on: July 06, 2006, 09:47:52 pm »
To be honest, the cylinder pressure issue is only an issue if the methanol content is very high, or if there is an inherent weakness already in place.  The water actually lowers the peak pressure slightly, but extends the pressure over a longer period of time, while the methanol does raise the peak pressure a bit.  They usually offset each other nicely, but, like on a 6.0 Powerstroke that already has known issues, if it is already on the ragged edge and water-meth is bolted on (or any other power adder at all) and it goes over the edge, the finger is pointed at the last power-adder, not the first, second, or third.
If you run 70% methanol, you will get really high pressures and run the risk of diesel knock - which is why we recommend no more than 50/50 mix.
Caddy (TD Project), Caddy 1.6D, etc etc.
  Snow Performance Water-Methanol Injection
Reply #9July 06, 2006, 11:50:16 pm
DVST8R
  • 535
Oxygen injection?
« Reply #9 on: July 06, 2006, 11:50:16 pm »
Quote from: "DVST8R"
Who?
I guess it is kinda hard to call it Piers when he is no longer there. :lol:
Yeah and to think I remeber when Piers and Bill @ DTT were still working for Brian Roth.
Hey whatever happened to sketchy Steve the transmission guy, he went to piers (sorry pdr) for a bit then dissapeared, he used to do on the side work, but was always really sketchy. Anyway [/HiJack]
Reply #10July 07, 2006, 09:10:00 am
Kantdrive55
  • 65
Oxygen injection?
« Reply #10 on: July 07, 2006, 09:10:00 am »
Steve has started his own shop called  TPS in Chilliwack.  Not quite so sketchy now that he is a buisiness owner.  Still builds a pretty good tranny.
  It seems like at BD we train em and then let them go out and start a business to compete against us. :lol:
  Sorry for the hijack.  I moderate forums too, I should know better :oops:
1993 TD Jetta
Reply #11July 07, 2006, 09:14:01 am
Kantdrive55
  • 65
Oxygen injection?
« Reply #11 on: July 07, 2006, 09:14:01 am »
Quote from: greggearhead
  Thanks Greg.  We are running it on a couple of our shop trucks and I love it.  We have studded our 6.0 so it isnt an issue any more.  We are also running it on our 02 Dodge.  It is a daily driver that puts over 600hp to the ground and it works awesome.
  I know I am definately going to get a kit and when I do I will post up the dyno numbers and graphs.
1993 TD Jetta
Reply #12July 07, 2006, 05:16:59 pm
Master ACiD
  • 328
Oxygen injection?
« Reply #12 on: July 07, 2006, 05:16:59 pm »
Quote from: hoyt
i just went out and turned on the oxygen from my torch and aimed it at a cup full of diesel. it didnt auto ignite. i tried it with gas too. again it didnt auto ignite. and to top it off, oxygen cant self ignite in a diesel cylinder because theres no fuel in the cylinder untill tdc, so you could run oxygen and not have auto ignition.
on the other hand, i agree with everyone else that oxygen would help create a really hot burn in the cylinder after the injectors did their job. it would probably help burn through pistons like a cutting torch.
Reply #13July 07, 2006, 09:50:30 pm
hoyt
  • 22
Oxygen injection?
« Reply #13 on: July 07, 2006, 09:50:30 pm »
Quote from: Master ACiD
Quote from: hoyt
"Auto-ignites" was probaly a little dramatic on my part.  Take a rag,
soak it is oil, diesel, grease, etc.   Then play the O2 over the rag.
The rag will start to smoke, then start burning.
This is the reason you never lub the regulators on a torch set.
--John
  '82 Diesel Vanagon
