Author Topic: What manual boost controller?  (Read 5292 times)
June 14, 2006, 12:48:41 pm
con
  • 106
« on: June 14, 2006, 12:48:41 pm »
I searched on ebay for a boost controller for a diesel, these are the results :
http://search.ebay.co.uk/search/search.dll?cgiurl=http%3A%2F%2Fcgi.ebay.co.uk%2Fws%2F&fkr=1&from=R8&satitle=boost+controller+diesel&category0=
Which one is most suited for my MK2 1.6 GTD?
I was also planning on buying a boost gauge, would this one work alright?
.http://cgi.ebay.co.uk/TIM-Boost-Gauge-2-Bar-52mm-Dia-Black-Face-Pod_W0QQitemZ8072515237QQcategoryZ72205QQrdZ1QQcmdZViewItem
Any help much appreciated, Thanks
Reply #1June 14, 2006, 01:15:27 pm
  • 5104
« Reply #1 on: June 14, 2006, 01:15:27 pm »
diesel and gas boost controllers are the same, get the cheapest one you can get that will support the boost you wanna run.
Reply #2June 14, 2006, 04:25:34 pm
BellCityDubber
  • 251
« Reply #2 on: June 14, 2006, 04:25:34 pm »
E-bay is okay for alot of these things.... I got my voodoo MBC off e-bay... it seems to work flawlessly....
Reply #3June 14, 2006, 07:03:37 pm
con
  • 106
« Reply #3 on: June 14, 2006, 07:03:37 pm »
Ok sweet, I take it all the boost gauges work for both petrol and diesel?
Reply #4June 14, 2006, 07:13:01 pm
QuickTD
  • 1156
« Reply #4 on: June 14, 2006, 07:13:01 pm »
You want a boost guage that reads manifold pressure only, 0-35psi or 0-2.5 bar would be a suitable range. Boost guages for petrol usually read vacuum as well as boost. A diesel is unthrottled so it doesn't develop manifold vacuum, so there is no need for a vacuum scale on a diesel boost guage.
Reply #5June 15, 2006, 12:11:58 am
« Reply #5 on: June 15, 2006, 12:11:58 am »
I got both kinds of guage in my car, and have yet to see vacuum... :D
I beleive my controller was $14 at McMaster Carr, but I had to do some threading and stuff.
Reply #6June 15, 2006, 03:58:05 am
Benjamin
  • 485
« Reply #6 on: June 15, 2006, 03:58:05 am »
so every bosstcontroller / bleedvalve, ... give you less lag?
Greetz, Benjamin
SMOG alert, engine running again!
Must make +250hp
Reply #7June 21, 2006, 05:47:28 am
con
  • 106
« Reply #7 on: June 21, 2006, 05:47:28 am »
My MBC arrived today. Does anyone have any links to pictures of a standard 1.6 TD turbocharger as I would like to study it more closely.
Reply #8June 21, 2006, 10:49:24 pm
LeeG
  • 401
« Reply #8 on: June 21, 2006, 10:49:24 pm »
http://www.putfile.com/dieseldude
the kkk24 picture probably what you have  You want to cut that line you see for the boost controller.  other picture is a K14.
'97 Passat TDI
Reply #9June 22, 2006, 02:56:16 am
con
  • 106
« Reply #9 on: June 22, 2006, 02:56:16 am »
Thanks those are excellent pics. So that line you referred to, That would be what they mean when they say to hook up to the boost source?
Reply #10June 22, 2006, 09:10:47 am
LeeG
  • 401
« Reply #10 on: June 22, 2006, 09:10:47 am »
yes, boost comes from the compressor side of turbo, through that line to the wastegate, which is the part with the fins on it in lower left of the side view picture.
'97 Passat TDI
Reply #11June 23, 2006, 06:07:25 am
con
  • 106
« Reply #11 on: June 23, 2006, 06:07:25 am »
ok excellent. What is that live made of, do I splice the tube from the MBC onto it? And is the wastegate actuator visible in any of those pics?
Reply #12June 23, 2006, 10:12:03 am
LeeG
  • 401
« Reply #12 on: June 23, 2006, 10:12:03 am »
there is no actuator visible, just the wastegate can (with fins at bottom) which contains the diaphram.  valve extends from diaphram into hot side of turbo, opens a passge to dump exhaust pressure out of the turbine area.
fspgtd has a thread with pictures of a kkk24 being dissasembled
edit  http://www.vwdiesel.net/phpBB/viewtopic.php?t=1841 /edit
line is steel, you probably need to take section out of the middle of it and attach the hoses from your controller to them, but check with the supplier for details of how the controller works
'97 Passat TDI
