Author Topic: compression leak at injector no. 1  (Read 4812 times)
June 12, 2006, 08:13:58 pm
prysm
  • 41
    • http://www.fernski.com
« on: June 12, 2006, 08:13:58 pm »
Hello
My engine appears to be ok after removing the head. Although I can hear
a psst sound at the injector no.1 I tried retourque but it did not help that much. I removed the injector and checked the crush washer it a smal dent on one side that apears to have been caught in the threads during assmebly I will try to replace the crush washer see if that helps.
I was wondering if you guys have any other method of improving the seal in the injectorsand glow plugs. Do you think I can use the teflon tape used in plumbing without causing damage to the injectors?
thanks
mazda B2200 2.2L R2 diesel
Reply #1June 30, 2006, 12:33:55 pm
MaxHedrm
  • 114
    • blog
Re: compression leak at injector no. 1
« Reply #1 on: June 30, 2006, 12:33:55 pm »
I think teflon tape would be a bad idea. Is that stuff heat resistant?
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #2July 02, 2006, 06:02:45 am
prysm
  • 41
« Reply #2 on: July 02, 2006, 06:02:45 am »
It's suppose to be heat resistant.
Anyway after replacing the heat sheild three times it seems to be ok now.
There was a small but deep scratch in the injector seat that seems to be causing the problem.
thanks
,Fernan
