TDI Engine -General Info
9mm Plunger too small for use on a TDI-M?
Topic: 9mm Plunger too small for use on a TDI-M? (Read 3988 times)
June 11, 2006, 05:43:00 am
Ziptar
June 11, 2006, 05:43:00 am »
I came across a VE IP from a old Jeep that had the Renault 2.1L Turbo Diesel. Based on the Tag Numbers it's a VE but, it has 9MM plungers.
Is 9MM too small to use on a TDI-M?? Should I grab it to for parts? I could use it for swapping the governor assembly over to a 4BT pump I suppose but, I don't know that the Renault RPM range is the same as the VWs.
June 11, 2006, 06:35:52 pm
lesharoturbo
June 11, 2006, 06:35:52 pm »
In my Winnebago (it has the Renault 2.1 also) The max rpm is set to 4800-5100 rpm's.
Hope theis helps
Bernie
June 11, 2006, 09:18:04 pm
hillfolk'r
June 11, 2006, 09:18:04 pm »
i say try it,whats the worst that happens,it wont run? ,i think itll run,it just wont be a "powerhouse",ive heard that its too small too,but has anyone actually tried it to see??
doit,and report back your findings
Throttle cables ftw
June 12, 2006, 03:14:11 am
Ziptar
June 12, 2006, 03:14:11 am »
Bernie
Thanks, actually it does help, seeing as how the redline in my TDI is 5000 RPM, I'd say it'll work.
hillfolk
Ok, I'll pickup the IP, It'll be a while before report back, I need a motor first :wink:
