2.5" exhaust 2 glasspacks enough?
Topic: 2.5" exhaust 2 glasspacks enough? (Read 5040 times)
June 06, 2006, 03:35:41 pm
sethyboy85
June 06, 2006, 03:35:41 pm »
I am getting a 2.5" exhaust on my car soon and was wondering if 2 glasspacks would quite the car down enough. right now it has the factory exhaust close to the turbo on my car and was very quite when the exhaust was clamp to the turbo DP going through the factory exhaust to the rear axle where it enlarges to a 2.25 GP and a turn down.
Would a 2.5" exhaust with 2 GP be quieter than a NA with 1 GP on the highway... I still like to hear my car but not drone me too death.
I can tolerate a decent amount of noise I ran my Turbo Daytona around for 1 summer with just a DP on that which ended right below the shifter and was actually quiet except for when you got on it.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
June 06, 2006, 03:58:00 pm
zooky
June 06, 2006, 03:58:00 pm »
I'm interested in this answer too, I want to hear the turbo :lol:
June 06, 2006, 04:04:35 pm
June 06, 2006, 04:04:35 pm »
i have a 2 1/4 inch exhaust with a resonator and a dynomax muffler, and my cars not loud at all.
June 06, 2006, 04:09:43 pm
hillfolk'r
June 06, 2006, 04:09:43 pm »
most any muffler,or glasspack will "kill" the turbo whisle,
the setup you wanna use will be qwiet,with some sound,try one glass pack at first,but leave a tailpipe you can remove,so you can add a second one (glasspack) if you want it quieter
Throttle cables ftw
June 06, 2006, 05:09:42 pm
Op-Ivy
June 06, 2006, 05:09:42 pm »
I have 2" new piping with a resonator and Flowmaster muffler. I can hear my turbo almost as much as my girlfriend's '03 Jetta 1.8 turbo!
June 06, 2006, 06:17:32 pm
sethyboy85
June 06, 2006, 06:17:32 pm »
Im not worried about the whistle, I have had many glasspacks on turbo cars and even alittle too close and blew the fiberglass out of one on a highway trip . I am mostly concerned with drone on the highway.
June 06, 2006, 06:53:33 pm
935racer
June 06, 2006, 06:53:33 pm »
1 glasspack gets rid of a lot of drone on the highway, 2 is perfect. One is great for aroung the city, but I like two for highway driving.
June 06, 2006, 11:22:58 pm
GypsyR
Newbie
June 06, 2006, 11:22:58 pm »
In my 81 TD I bought a Thrush "turbo" muffler from the local parts store for $20. I was running a straight 2.5" pipe for a while and it was pretty obnoxious. The exhaust sounds a lot more civilized now. Due to a semi-custom K+N conical airfilter setup I can hear my turbo whine just fine. Even better now that the loudass exhaust is under control.
The gas turbo guys claim FlowMasters actually have a small negative performance effect on turbo gas cars. Flowmasters basically work by dampening "exhaust pulses". After the exhaust has been blended by a turbo or two, there aren't really any of those type pulses anymore. Therefore FlowMasters aren't usually turbo guys' first choice in mufflers anyway.
Nothing against FlowMasters, I have a pair on my other truck and a Mustang and like them just fine.
June 07, 2006, 12:54:40 am
Maarten
June 07, 2006, 12:54:40 am »
I ran 1 Trush glasspack on my 3" DP / 2.5" exhaust after driving without for some weeks, 90% of the turbowhine went away :cry:
My next project will include a (permanent) bypass for some good symphony
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
June 07, 2006, 01:00:08 am
June 07, 2006, 01:00:08 am »
seems to me having the pipe all the way to the back of the car quiets things as much as most 2.25 mufflers.
On my turbo Caddy, I tried about 5 different muffers with a side exit exhaust just behind the door, and glasspack, gineric turbo, and Flowmaster all sounded damn close to the same. I love hearing the turbo spin down after shutoff.
June 07, 2006, 11:26:30 pm
GypsyR
Newbie
June 07, 2006, 11:26:30 pm »
It's worth noting that DynoMax/Thrush "Turbo" mufflers are not the same thing as DynoMax/Thrush "glasspack" mufflers. As seen here at Summit Racing
http://store.summitracing.com/egnsearch.asp?N=400358+115&Nao=20#rstop
Reply #11
June 08, 2006, 06:08:27 pm
hillfolk'r
Reply #11 on:
June 08, 2006, 06:08:27 pm »
this is perfect,hear it??
scroll down thru the post and check it out on photobucket,some people said they were having a problem on putfile
its 2.5 inch,straight pipe,it ends at the axle beam,with a turndown,easy+simple,and sounds great
http://www.vwdiesel.net/phpBB/viewtopic.php?t=4120
Throttle cables ftw
Reply #12
June 08, 2006, 06:15:07 pm
zagarus
Reply #12 on:
June 08, 2006, 06:15:07 pm »
so will i get a decent whistle, with 2.5 inch downpipe and piping into a magnaflow muffler?
