14mm head/plunger
Topic: 14mm head/plunger (Read 17572 times)
June 04, 2006, 09:35:41 pm
Dr. Diesel
Authorized Vendor
14mm head/plunger
June 04, 2006, 09:35:41 pm »
I recently heard about there being 14mm heads available. I searched the bosch catalog top to bottom and the biggest I could find is 12mm. Curious, I sent this site's 14mm head supplier an email regarding this. No reply.
I dug up a 12mm plunger and did some measuring.
Check out the pic.
The actual plunger part of the plunger is of course, 12mm. The base of the plunger is 14mm. Could this be confusing people into thinking a 12mm plunger is 14mm?
June 04, 2006, 10:56:10 pm
Moderator
14mm head/plunger
June 04, 2006, 10:56:10 pm »
I'm pretty sure there isn't confusion between 12mm and 14mm.
I've heard about 14mm from multiple sources and one of them is a pump shop who built a VW IDI w/ 14mm for some kind of machinery. Definitely low RPM for that application.
Others can chime in here and verify the 12 vs. 14mm.
http://www.tunezilla.com
93 Eurovan AHU TDI
97 Golf Variant Syncro 1.9L 1Z TDI -
sold and missed
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
June 05, 2006, 07:33:12 am
Dr. Diesel
Authorized Vendor
14mm head/plunger
June 05, 2006, 07:33:12 am »
Any idea what manufacturer produces it?
June 05, 2006, 09:03:52 am
sebzero
14mm head/plunger
June 05, 2006, 09:03:52 am »
http://www.diesel-speed-shop.com/index_fichiers/Page2023.htm
:wink:
Auto-emotion
June 05, 2006, 03:06:30 pm
RedRotors
14mm head/plunger
June 05, 2006, 03:06:30 pm »
14mm are not a Myth.. One is coming down here in a few weeks. Caddy and me worked together to build the head.. 14mm is custom made.. Bosch stop at 12mm.
I'll post pics..
Marc/
PS: Doc, drop me a line if you are interested by them..
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
www.mikrotuning.com
www.hflox.com
June 05, 2006, 04:31:07 pm
Dr. Diesel
Authorized Vendor
14mm head/plunger
June 05, 2006, 04:31:07 pm »
aha! it all makes sense now.
Thanks.
June 05, 2006, 06:11:32 pm
935racer
14mm head/plunger
June 05, 2006, 06:11:32 pm »
Ummm sent pm to redrotors... :twisted:
June 05, 2006, 08:52:08 pm
hillfolk'r
14mm head/plunger
June 05, 2006, 08:52:08 pm »
id blow my smallshaft/12mm head pump apart with that...especially on my tdi-m,with the higher breakover of the tdi injectors...ive seen that plunger before... that thing is nuts,yeowie :twisted:
Throttle cables ftw
June 25, 2006, 12:45:09 pm
RedRotors
14mm head/plunger
June 25, 2006, 12:45:09 pm »
Here's a couple pictures.. I only had a 12mm to compare, but you can easily see that this thing is HUGE and will pump a LOT of fuel.. :twisted:
The 14 is on the right.. :wink:
Nobody has this thing in NA, and Dave will be the first one to test it..
I would expect a lot of fuel and the need of fat injector.. Small holes will create too much back pressure.. I thing that 0.240 + will be needed as well as a fuel cooler.
Cheers,
Marc/
91' VW Golf Country
www.mikrotuning.com
www.hflox.com
June 25, 2006, 04:55:15 pm
Slave2School
14mm head/plunger
June 25, 2006, 04:55:15 pm »
What will the max sustainable RPM be? and props for being so psycho
Waiting for a bigger better diesel to come along.
2002 ford focme wagon
June 26, 2006, 02:00:22 pm
Benjamin
14mm head/plunger
June 26, 2006, 02:00:22 pm »
gr8 stuff, i cant get it how to get this build...
I thought 12mm breaks if it takes to high revs, ...
Anyway, its pretty cool
Greetz, Benjamin
SMOG alert, engine running again!
Must make +250hp
Reply #11
June 26, 2006, 10:26:42 pm
935racer
14mm head/plunger
Reply #11 on:
June 26, 2006, 10:26:42 pm »
WHOA... :shock: Thats badass :twisted: I will be honored to let you all in on the results from this beast. I am actually kinda scared... I think we now have enough fuel for 250WHP+. And I know I have enough air... My poor bottom end
I'd hate to see a pic comparison of that 14mm and the stock 9mm, hey redrotors
Reply #12
June 28, 2006, 08:07:59 pm
firestorm13666
14mm head/plunger
Reply #12 on:
June 28, 2006, 08:07:59 pm »
So what engine was it tested in and what kind of power did it make?
Reply #13
June 30, 2006, 09:52:53 am
RAMMSTEIN
14mm head/plunger
Reply #13 on:
June 30, 2006, 09:52:53 am »
RedRotors just got it and will ship it soon to BC.
I saw it, it's massive! :shock:
Rammstein
In abscence of light, darkness prevails.
Reply #14
June 30, 2006, 05:57:38 pm
hillfolk'r
14mm head/plunger
Reply #14 on:
June 30, 2006, 05:57:38 pm »
i still wonder if it would make my pump a real"time bomb",mines workin great still,i dont think its a problem putting a 12mm on a small shaft pump at all,people get all freaked out from like 1 story..
i would maybe try it if this hy 35 deal goes real good+needs more fuel,,oh ill have some pics of the fabbed exhaust flanges soon......
Throttle cables ftw
14mm head/plunger
