Author Topic: has anyone raced there diesel in the 1/4 mile?  (Read 9294 times)
September 03, 2004, 08:23:56 am
SMOKEYDUB
  • 630
« on: September 03, 2004, 08:23:56 am »
I did with just alittle bit of turbo mods a 18.3. Tonight I'm going again and i think for sure im going to get low 17's
86 jetta td 1.6
mazda 626 intercooler
and "the screwdriver trick"
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1September 03, 2004, 06:53:55 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #1 on: September 03, 2004, 06:53:55 pm »
18.1 stock A2 w/ 2.5" exhaust. beat an impala!  :twisted:
Reply #2September 06, 2004, 04:21:22 pm
TDIMeister
  • 284
Re: has anyone raced there diesel in the 1/4 mile?
« Reply #2 on: September 06, 2004, 04:21:22 pm »
Quote from: "SMOKEYDUB"
How do you plan on going from 18.3 to low 17s?
Reply #3September 06, 2004, 08:44:01 pm
fspGTD
  • 1529
    • http://home.comcast.net/~vwgtd
« Reply #3 on: September 06, 2004, 08:44:01 pm »
Years ago when my Rabbit was a heavy (2250'ish lb) street machine and with 14psi but with the stock revv limiter, I ran a best 1/4mi time in the low 17's, but I remember thinking that I'd have been in the high 16's if I was able to take a pass without the pop-off valve opening.
Jake Russell
Dieselicious Turbocharger Upgrade/Rebuild Kits
Reply #4September 07, 2004, 07:56:59 pm
Blades
« Reply #4 on: September 07, 2004, 07:56:59 pm »
My friend 1997 Jetta 1.9TD
14psi
no IC
no smoke whatsoever
pretty much everything in Smog's DIY (Actualy, Smog did the settings)
16.72
Quick fact: 7 year experience in drag racing street cars.
Reply #5September 08, 2004, 01:44:22 am
Cheesetoast
  • 285
« Reply #5 on: September 08, 2004, 01:44:22 am »
where is "smog's DIY" located?
Quote from: "Blades"
14psi
no IC
no smoke whatsoever
16.72
Reply #6September 08, 2004, 04:02:39 am
Reply #7September 12, 2004, 11:23:40 pm
MK3 GTD
  • 48
« Reply #7 on: September 12, 2004, 11:23:40 pm »
havent run on the track, but i did a few g-tech runs with my mk3 1.9td tuned for street use.
2755 lbs
cat back 2.5" exhaust
20 psi boost
no i/c
governor disabled
timing solenoid wired for constant power
"throttle" lever stops backed off completely for maximum travel
fueling screw adjusted for a light fog of smoke while on boost
2.431 60 ft
6.794 330ft
10.476 1/8th
13.686 1000ft
16.392 1/4 @ 84.23 mph
8.648 0-60
1996 Golf 1.9TD
1984 Rabbit 1.6TD
1987 Jetta Coupe 1.6D
Reply #8September 13, 2004, 09:10:52 am
dieseltech
  • 129
    • http://www.geocities.com/dean16v/Page_One.html
« Reply #8 on: September 13, 2004, 09:10:52 am »
i got a [email protected]
i think if i had better tires i would have been faster.
i spun through first and a bit in second
25lbs boost
sparco air/water i/c
water mister
bilzzak snow tires :?
modded pump
2.25 mandrel exhaust streight pipe
and just a light haze of smoke
86td 2 door
86 td jetta power everything dd (update off the road for major resto).  97tdi bare bones, DD
and a private junkyard of various other vw/audi/bmw/peugeot/volvo/toyota diesels!!!
Cummins has the worlds record for being the most efficient engine ever!!!!!
for converting fuel into noise!
Reply #9September 16, 2004, 03:25:31 pm
Artsi
« Reply #9 on: September 16, 2004, 03:25:31 pm »
Around 10 years ago we had a 1.6TD IDI Golf hammering well below 15 sec quarter mile times.
According to a self employed turbo shop prefessional (who had a peek under the hood) said it had a Garrett T03, 0,48AR turbine with 45trim compressor charger installed. Such charger can be found in a Saab 900 turbo from very late 1980's.
Reply #10September 18, 2004, 09:48:35 am
dieselpower
  • 177
« Reply #10 on: September 18, 2004, 09:48:35 am »
i went out last night and my last run was 18.12@75mph
that was running 15 psi
no i/c(which is coming in soon)
pretty much stock pump...just turned up the fuel
crappy all season tires
and it was also my first time out racing. the rest of the times were around 18.4
this is in a mk1 1.6 TD rabbit with no seats in it
84 rabbit 1.6TD
because real cars don't have sparkplugs
Reply #11October 30, 2004, 07:25:05 pm
hillfolk'r
  • 1532
1/4 time
« Reply #11 on: October 30, 2004, 07:25:05 pm »
ok at waterfest, i did a 15.7@85,,and thats no ic,,whupped clutch,and now i have a big 12mm pump,and centerforce clutch let my t3 go closed wastegate all the time,,raceware studs,,like 35 psi all the time,,i got it it had 160k on it,,207k and runnin strong,,i think,w/ compound setup+ic,,ill hit 14s :twisted:
Throttle cables ftw
Reply #12September 22, 2010, 11:20:29 pm
81 vw pu
« Reply #12 on: September 22, 2010, 11:20:29 pm »
I ran my Caddy last weekend and the best I could get was a 18.28 @ 72.13 MPH.
I was the quickest 4 cylinder diesel there, ( because I was the only one).
10 lbs. boost
35 shot of nitrous
Gov mod
Advance Mod
No IC
2" straight-pipe exhaust
B-100 Home-Brewed Biodiesel
Reply #13September 23, 2010, 05:45:44 am
vwjunkie53
  • 98
    • The Volvo diesel forum
« Reply #13 on: September 23, 2010, 05:45:44 am »
I've got down to a 16.07 @86 with my 760 volvo with D24t.  I broke the rear end before I could get into the 15s... It was getting faster each pass as I got the launch better, but I was having problems spinning just one tire if I launched too hard.  I've got a locking diff now so I should be able to get into the 15s since I'll finnally be able to get off the line.
Not bad for a car that weighs over 3000lbs
Jason
1984 Volvo 760 GLE,  "built" D24T w/ARP studs, MLS head gasket, ported/polished head, 3 angle valve job, NA cam, 56mm T3/T4, NA manifold, FMIC w/ 3" alum piping, 3" turbo back, detailed in CAT yellow. T-5 manual swapped w/ Clutchnet 6-puck.  Best of 16.07@86mph with orig. worn out engine.
Reply #14September 23, 2010, 05:49:41 am
vwjunkie53
  • 98
