Author Topic: Intake upgrade worthwhile?  (Read 2171 times)
May 17, 2006, 10:01:06 pm
MadCityMike
  • 21
« on: May 17, 2006, 10:01:06 pm »
Just wondering if the stock airbox & filter on a 94 AAZ equiped Jetta is decent, or would an upgrade be worthwhile?   I've seen the swiss cheese mods, but that still utilizes the same sized filter.    I'm not a fan of K&N type filters either.  I just upgraded the box in my 7.3L Powerstroke truck and wow did that make a difference in lowering EGT temps and quicker turbo spool up.   So I now have a perfectly fine stock airbox designed for a 7.3L that I was considering swapping into the Jetta.   I would think it would flow better then the stock one, but if the stock one flows enough that an upgrade isn't worthwhile then I won't bother.    Should I do it?
Mike
Mike
94 Jetta, 1.9l TD AAZ code
Reply #1May 18, 2006, 01:19:26 pm
Patrick
  • 1034
« Reply #1 on: May 18, 2006, 01:19:26 pm »
I can only thimk of one way to find out, and it starts with the car as is and a stopwatch.....................................
