Author Topic: Engines for sale in Washington  (Read 4478 times)
May 16, 2006, 09:22:08 pm
vwmike
  • 1158
« on: May 16, 2006, 09:22:08 pm »
I'm still trying to clear out and get rid of things I don't need and I don't forsee using.
Preliminary list:
-N/A 1.6 Bottom end - 240k on it. It came out of an '84 Rabbit. I found a rebuilt engine for the car I was going to put it in so now it's just sitting in the corner of my garage. It supposedly ran though I'd probably rebuild it if I wanted the car to drive for another decade. Make me an offer and come get it.
-AAZ 1.9TD longblock. I had this shipped over from Ontario and then a TDI fell into my lap and has taken priority. It is really dirty like you'd expect a Candian engine to be. There is a bit of a ridge at the top of the cylinders. It would probably run as it is, but a rebuild wouldn't be a terrible idea. The head looks good still with only the typical small cracks between the valves. The proper 1.9 intake manifold, injectors, injection pump bracket, vacuum pump, oil filter flange, oil cooler (bigger), crankcase vent tube, and valve cover are also included. No turbo, and no injection pump or exhaust manifold. I'm not sure what it's worth at this point. Send me a PM if you're interested.
Reply #1May 21, 2006, 07:42:15 pm
vwmike
  • 1158
« Reply #1 on: May 21, 2006, 07:42:15 pm »
They're still here...
Reply #2May 26, 2006, 12:27:11 pm
vwmike
  • 1158
« Reply #2 on: May 26, 2006, 12:27:11 pm »
The 1.9 is gone. If anyone still needs a 1.6 though, it's here.
Reply #3May 27, 2006, 12:44:29 am
ezekiel
  • 147
« Reply #3 on: May 27, 2006, 12:44:29 am »
thanks again Mike!
I'm actually going to pick up the pickup today, so it was perfect timing this weekend, new truck, and new motor.
