Author Topic: Rear drums maybe shot or maybe it's my shoes  (Read 4142 times)
May 15, 2006, 09:43:11 pm
Darkness_is_spreading
  • 288
« on: May 15, 2006, 09:43:11 pm »
I recently installed a new driverside e-break cable, it went smoothly andI put in a new cotter pin and fastened her all up,  I go to test the breaks and notice a rubbing noise comming from the back drums.
The noise  goes away after a stop breaking, and after they are heated up.
Are my drums out of round or do I need to adjust the breaks.
92 Jetta 1.6 T (Sleepin)
Reply #1May 15, 2006, 10:04:12 pm
LeeG
  • 401
« Reply #1 on: May 15, 2006, 10:04:12 pm »
So the noise comes and goes?   I'd recommend taking it apart again and looking for whats rubbing.   shoe hold down spring/retainer comes to mind.
If the noise was a one time thing after re-assembly, it may have just been some crud in the drum.  Like a bit of rust from the drum ridge.
Drums out of round would result in pulsating pedal and a jerky rolling motion at slow speed when you pull on the e-brake.
Most common signs of rear brakes needing adjustment would be low brake pedal or high  parking brake travel.  A2 auto-adjusters seem to be pretty good
'97 Passat TDI
