Author Topic: What makes the 1.6 so much better than the 1.5?  (Read 12341 times)
May 11, 2006, 11:43:13 pm
rabbid79
  • 684
« on: May 11, 2006, 11:43:13 pm »
Hello All,
I've been hanging around this forum for quite a few months and I feel that there is a wealth of information and wisdom here not found anywhere else.  I'm sure you folks can answer the title of my post better than anyone.  This discussion concerns the differences between the 1.5L and the Naturally Aspirated 1.6L.  Why is there so little interest in the 1.5?  Is the N/A 1.6 THAT much better?  I'm sure that the sheer number of 1.6s produced compared to 1.5s has something to do with its popularity.  Plus, because they're older, there are simply fewer 1.5s left.
So, how do the two engines compare mechanically?  Here's what I know about the 1.6:
>Obviously larger in displacement due to stroke
>Larger piston pins
>Larger head bolts
>Hydraulic heads on newer 1.6s
Here are some things I don't know about either:
>Forged pistons?  As far as I know the 1.5's are cast.  Are the N/A 1.6's cast or forged?
>Forged crankshafts and connecting rods?  Which engine has which?
>Cam differences?
>Block differences?
>Head differences (other than head bolt size)  Does the 1.6 flow better?  Does it have bigger valves?
>Pump head size differences?
I'm considering building a 1.5 turbo and feel that some of the 1.5's shortcomings (such as head bolt size, lack of oil squirters, etc.) can be be addressed.  I don't consider the 1.5's stroke to be a shortcoming and intend to leave it at 80 mm.  I'd just like to know why I've never seen a 1.5 modified to the same extent as a 1.6.  I know, most people would tell me to modify a 1.6 or 1.6TD instead, but that's just it.  I want to do something different, and that's why I'd like to use the 1.5.  For some reason, you just don't see hot 1.5s.  What else am I missing?  Don't get me wrong, I think the 1.6 is a good motor.  I'm not trying to stir up a hornet's nest, I'm just looking for answers.  Thanks.
'15 WRX
Reply #1May 12, 2006, 12:14:05 am
Katmandu
  • 47
« Reply #1 on: May 12, 2006, 12:14:05 am »
The 1.6 is better because it has 4HP MORE than the 1.5!  :lol:
 48HP (for the 1.5) -Vs- 52HP (for the 1.6). Yea! One more lawnmower's worth of extra power!
 Seriously though, the 1.5 is just as good as the 1.6. There are simply not many 1.5s left is more likely the reason you don't see them around.
 Also, I've been told be a VERY reputable VW Diesel Parts dealer that 1.5 pistons are extremely difficult to find new anymore. That making rebuilding one not a real viable option.
 BTW, I have a 1.5 list on EBay right now.  8)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8064505057
Reply #2May 12, 2006, 12:57:11 am
vwmike
  • 1158
« Reply #2 on: May 12, 2006, 12:57:11 am »
I think you're on the right track with the popularity of the 1.6 being due to it's relative age and production numbers more than anything. The biggest turn-off for 1.5's is basically the head bolts. With the 11mm bolts they tend to go through head gaskets like.....well I'll save the analogies for later. Regardless, it is a concern in terms of reliability and most of the time when an engine is replaced nobody bothers to concern themselves with the 1.5.
Reply #3May 12, 2006, 05:08:22 pm
« Reply #3 on: May 12, 2006, 05:08:22 pm »
not to mention they never came turbo.
Reply #4May 12, 2006, 10:01:45 pm
hillfolk'r
  • 1532
« Reply #4 on: May 12, 2006, 10:01:45 pm »
look at how much torque the 1.6 na makes over the 1.5,,and it makes more at a lower rpm...... i think its almost 15 foot pounds...thats what you feel,,,some of the power loss is in the pump,cam, etc,a lot of little things that add up
Throttle cables ftw
Reply #5May 13, 2006, 12:07:42 am
rabbid79
  • 684
« Reply #5 on: May 13, 2006, 12:07:42 am »
So far so good.  It's been 24 hours and so far no one has given me a reason not to try it. :D
'15 WRX
Reply #6May 13, 2006, 02:04:31 am
« Reply #6 on: May 13, 2006, 02:04:31 am »
Quote from: rabbid79
other than engineering enhancements done to the 1.6 that the 1.5 obviously does not have such as head bolt upgrade as mentioned before.
I would rather have the improved engine, but would settle with the older one if I had to.
I wonder if a 1.5 block could be bored out to handle 1.6 stock pistons?  I'm guessing it would be a bad idea due to added stress on the crank, rods, block... etc, but 1.5 pistons are rare.
Reply #7May 13, 2006, 09:55:43 am
rabbid79
  • 684
« Reply #7 on: May 13, 2006, 09:55:43 am »
Ok, good, this is exactly where I'm trying to go with this.
Head Bolts:  Why wouldn't Raceware or ARP head bolts be able to make up for the flimsy 11mm factory bolts?  And while we're at it, what about head gaskets.  Since 1.5s and 1.6s have the same bore, wouldn't 1.6 TD head gaskets work?  Ok, here's an issue.  The head gasket bolt holes would be larger on the 1.6 TD head gasket.  What kind of issues would this cause?  And finally, most people want to upgrade to metal headgaskets anyway.  I'm assuming there isn't one made for the 1.5.  Does anyone have experience having a custom one made.  Copper or something?
Pistons:  Why go with the 1.6 pistons?  Are they superior in some way?  I know the turbo pistons have the oil squirter cutouts.  But are the 1.6 pistons forged where the 1.5s are not?  BTW, there's a set of KS 1.5 pistons (stock size) on eBay for $150.  What do people know about KS?
Thanks for your replies.
'15 WRX
Reply #8May 13, 2006, 02:20:35 pm
hillfolk'r
  • 1532
« Reply #8 on: May 13, 2006, 02:20:35 pm »
i cant remember,didnt the 1.5 have a cast crank??i remember mine(1.5) that was in my 80,i didnt like the powerband,you really had to rev it alot to get a little,i swapped to a 1.6 when it blew up+5 speed... it seemed like the 1.6/gti trans had good power,and way torquier,,,,besides,, i guess you said 1.5 parts are a little hard to find,another use then for a stock 1.6,,,now if you are rebuilding a stocker 1.5,then yea do it,but to me,unless its allyou have,find somethin bigger maybe??im not tryin to axe   your idea,just sayin its alot of work to do an engine,think about it first before diving in :wink:
heh toobad
http://forums.vwvortex.com/zerothread?id=2496239
Throttle cables ftw
Reply #9May 13, 2006, 06:55:24 pm
rabbid79
  • 684
« Reply #9 on: May 13, 2006, 06:55:24 pm »
So I'm hearing weak block near the headbolts, and possibly a cast crank.  Neither of these things bode well for a modified 1.5.  I presume that the N/A 1.6 has a forged crank?  Can anyone confirm or deny that?  Were there any special circumstances on the block(s) that broke near the headbolts?  How often have you seen that?  The headbolt holes didn't have any oil in them that would cause them to break when they were torqued down or anything?  FYI, some of my inspiration comes from the fact that VW built a 160 HP version of this motor back in the '70s when they were developing it.  Unfortunately, I don't have any specific details.
'15 WRX
Reply #10May 13, 2006, 10:56:52 pm
« Reply #10 on: May 13, 2006, 10:56:52 pm »
160 hp?  :shock:   from a 1.5 liter engine???  Couldn't be diesel.  Diesel technology back then was less than great.  Even squeezing 160hp out of a gasoline 1.5 litre engine would be hard without a turbo, if not impossible.  Using the stronger diesel parts, and a whole lot of fuel could possibly do it though :)
Reply #11May 14, 2006, 09:25:38 am
rabbid79
  • 684
« Reply #11 on: May 14, 2006, 09:25:38 am »
Well, I was reading from the SAE paper concerning the development and evolution of the 1.5 diesel from the 1.5 gas.  They did use turbo charging to achieve 160 HP, but it doesn't say specifically that it was the diesel that made that much power.  Instead it says "the basic powerplant".  You could be right.  Perhaps it was the gas version that made that much power.  Just the same, since the diesel was derived from the gas, it's good to know that the block/crank/rods/head were able to tolerate that much power - even if only for a while.
'15 WRX
Reply #12May 14, 2006, 10:48:54 am
vwmike
  • 1158
« Reply #12 on: May 14, 2006, 10:48:54 am »
The gas engines are stout. I've turbocharged several of them and they've always held up quite well. Making 160hp from a 1.5 (gas engine) actually isn't all that tough with a turbo strapped to the back.
Reply #13May 16, 2006, 09:36:50 am
chrissev
  • 694
« Reply #13 on: May 16, 2006, 09:36:50 am »
1.6 engines have angle torque bolts that stretch when you tighten them.  1.5s don't.  Not sure if you can get angle torque bolts for the 1.5, but it would definately help as they tend to go through head gaskets at a rate of 1 per 75,000km.
1.5 engines were all solid lifter, most 1.6s were hydraulic.  You can't use a hydraulic head gasket on a solid lifter engine.  The fibre gaskets were pretty much junk anyway and on the turbos they are just plain funny.  Imagine putting 10 psi of boost into a 23/1 compression ratio 1.6 diesel engine, and all that is holding it all in there is a metal rim with a fibre gasket behind it?  The head gaskets didn't last very long.
The metal head gasket lowers compression slightly.  All metal head gaskets are hydraulic, so they wouldn't fit on a 1.5 engine anyway.
The 1.5 diesel was derived from the gas engine, the 1.6 wasn't (it was a completely new engine).  This is another reason to avoid the 1.5s.  Gas to diesel conversions are notoriously bad (remember the Chevette diesel?)
Reply #14May 16, 2006, 10:28:43 am
vwmike
  • 1158
« Reply #14 on: May 16, 2006, 10:28:43 am »
The 1.5's can use the same 11mm stretch bolts that are available for gas engines. Alternatively, they make head studs for gas engines. Those should also improve durability.
