Author Topic: 1.7 Diesel pistons  (Read 9897 times)
May 09, 2006, 06:12:07 pm
scopefrfd
  • 289
1.7 Diesel pistons
« on: May 09, 2006, 06:12:07 pm »
has anyone used the 1.7 diesel pistons.  I have the opportunity to get some and I wanted to get some feeedback.
The 1.7 pistons brings the hp up to 57-58 very close to an eco-turbo diesel.  Basically turbo power with none of the associated problems/costs of a turbo diesel
Reply #1May 10, 2006, 04:06:40 pm
Kudagra
  • 738
    • www.no-coast.com
1.7 Diesel pistons
« Reply #1 on: May 10, 2006, 04:06:40 pm »
1.7?
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #2May 10, 2006, 05:36:19 pm
scopefrfd
  • 289
1.7 Diesel pistons
« Reply #2 on: May 10, 2006, 05:36:19 pm »
yes, 80mm diesel pistons
Reply #3May 10, 2006, 06:05:45 pm
tylernt
  • 344
1.7 Diesel pistons
« Reply #3 on: May 10, 2006, 06:05:45 pm »
Where can you buy 1.7 pistons? Would be a nice power upgrade, assuming the 1.6 block can be safely bored out that far.
'82 Diesel Rabbit, '88 Fox RIP, '88 Jetta (work in progress)
Reply #4May 10, 2006, 06:41:25 pm
scopefrfd
  • 289
1.7 Diesel pistons
« Reply #4 on: May 10, 2006, 06:41:25 pm »
the pistons are factory.........vw actually made a 1.7 L diesel in europe using the same 1.6L block.  The ones I can get are also moly coated....the only drawback is they are not notched for td engines.
Reply #5May 10, 2006, 10:50:14 pm
935racer
1.7 Diesel pistons
« Reply #5 on: May 10, 2006, 10:50:14 pm »
80mm bore would be fine as far as  the block goes, and yes there are 80mm IDI pistons for the 1.9's but a factory 1.7? Haven't heard of that, what size is the wrist pin and whats the pin height on the piston? I highly doubt they are the same as the 1.6.
Reply #6May 11, 2006, 05:14:58 am
HP
  • 225
1.7 Diesel pistons
« Reply #6 on: May 11, 2006, 05:14:58 am »
I have no knowledge of a VW 1.7D either!
Reply #7May 11, 2006, 07:05:50 am
Maarten
  • 339
1.7 Diesel pistons
« Reply #7 on: May 11, 2006, 07:05:50 am »
I never heard of a VW 1.7 diesel in a passenger VW... I know the used a 1.7L engine in the transporter T3/T4, but I don't know if that is the same engine as the 1.6 (and the pistons can be used).
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #8May 11, 2006, 05:56:34 pm
scopefrfd
  • 289
1.7 Diesel pistons
« Reply #8 on: May 11, 2006, 05:56:34 pm »
they came in T2's and is basically a 1.6 with larger bore pistons
Reply #9May 12, 2006, 05:55:32 am
1.7 Diesel pistons
« Reply #9 on: May 12, 2006, 05:55:32 am »
Engine code KY, and in my engine code catalog it is listed as a 1.8.  Naturally aspirated, 57 hp, from years 84 to 92.  Piston bore is 79.48mm.
84 Scirocco 8v
00 Camaro L36 M49
Reply #10May 12, 2006, 06:39:39 am
scopefrfd
  • 289
1.7 Diesel pistons
« Reply #10 on: May 12, 2006, 06:39:39 am »
I think it would be a great set of pistons for a td project.  Only problem is the pistons would have to be clearanced for the oil squitters in a td block.
Reply #11May 12, 2006, 07:06:40 am
tylernt
  • 344
1.7 Diesel pistons
« Reply #11 on: May 12, 2006, 07:06:40 am »
You should be able to do without squirters if you have the piston tops thermal coated.
Reply #12May 12, 2006, 08:32:42 am
scopefrfd
  • 289
1.7 Diesel pistons
« Reply #12 on: May 12, 2006, 08:32:42 am »
The tops are already coated...but I don't know if it's a thermal barrier or a moly coating
Reply #13May 12, 2006, 09:02:21 am
tylernt
  • 344
1.7 Diesel pistons
« Reply #13 on: May 12, 2006, 09:02:21 am »
I don't know if moly has any thermal properties, the stuff I'm thinking of is either ceramic or that fancy zirconium oxide (?) stuff, forget the exact name at the moment.
Reply #14May 12, 2006, 04:53:15 pm
935racer
1.7 Diesel pistons
« Reply #14 on: May 12, 2006, 04:53:15 pm »
Hmmmm, so maybe its possible that that guy wasnt bull ***ting me after all. I was talkign to a guy that built a 1.7 about 10 years ago, he said he used some 1.9 pistons or some rods from a vw marine engine that made his engien a 1.7, he knew he had 79.5mm pistons but he couldnt remember if he had to change the rods or not. I figured he was just yanking my chain but I know there was some cool vw marine stuff liek intake manifolds and stuff that were way better than what we have on our cars.
