Author Topic: video link of an insane rabbit (gas)  (Read 6124 times)
May 09, 2006, 02:13:00 am
Dr. Diesel
  • 1341
Reply #1May 09, 2006, 05:18:05 am
shwartzbewithyou
« Reply #1 on: May 09, 2006, 05:18:05 am »
Ya I saw that posted on teh TEX a while ago, crazy fast.  Sounds like trouble waiting to happen to me.
Have you ever found a link to see the mods that he did?
Reply #2May 09, 2006, 10:12:53 am
VWRacer
  • 649
« Reply #2 on: May 09, 2006, 10:12:53 am »
Wow...that is impressive!  :shock:
Peak numbers are...
(Absolute?) manifold pressure of 1.96 kg/cm3 (28.0 psi)
Peak RPMs of 7500. Sounds like a 4-valve...my 8-v non-crossflow will rev to 8000, but it doesn't sound that smooth.
Max speed of 305 kph (189 mph). In a 77 Rabbit? That takes some major stones...  :lol:
I too would like to know what kind of mods he's done!
Stan
Stan
C-Sports Racer
Reply #3May 09, 2006, 10:18:56 am
BlackTieTD
  • 1512
« Reply #3 on: May 09, 2006, 10:18:56 am »
pretty sure 16v turbo on that one... its the silver 77?
i've always called speedo calibration into question but if its accurate,  :shock:
even if it isn't accurate, very impressive.
Reply #4May 09, 2006, 11:37:41 am
VWRacer
  • 649
« Reply #4 on: May 09, 2006, 11:37:41 am »
Yeah, good point about the speed. I used this calculator to get an idea of top speed. With the 155-70-13 tires which came stock on a '77 Rabbit, along with the base FN trans, it calls for a top speed of 262 kph/161 mph. If I bump the tire size up to the 205-55-14 commonly fitted to the first-gen GTI, I get 277 kph/172 mph. If he slipped in an FO with its slightly taller 5th gear, he could get up to 297 kph/184 mph with the bigger tires.
If he swapped in a set of stock 2002 TDI wheels with 195-55-15's, he bangs out a 304/189 top speed! Of course, now we come to the hp-required equation, where I think he falls short. I don't recall the drag coefficient of the '77 Rabbit, but cars of that era typically need about 500 hp to get to 200 mph. I doubt that a 1.8 or 2.0 can haul that drag bucket up that high.
The most I've seen from streetable (road raceable - not drag cars) 1.8T's is about 350 hp, and that's with a dry sump and lots of go-fast dollars spent on it. In a barn door like a Rabbit, that might be good for close to 150 mph, but 190? I really doubt it.
Just my 2 euro-cents...  :lol:
Stan
Stan
C-Sports Racer
Reply #5May 09, 2006, 11:54:56 am
vwmike
  • 1158
« Reply #5 on: May 09, 2006, 11:54:56 am »
I can guarantee you he isn't using an 020 gearbox. At the least it's probably an 02A or an 02J, but I would look to an 02M (6 speed) to try and get that kind of power down. As I recall the car was in fact a 16v turbo and ~500hp is totally doable if you're not trying to make an endurance racer. These engines can take a serious beating if only for short periods of time. Sustained power output like that may very well toast the engine.
Even still...189 mph (or anywhere close) is quite the insane move in a Rabbit. I've never had a Rabbit over about 120 mph and it can get a bit shady up there. He must have done something to improve the aerodynamics considerably.
Reply #6May 09, 2006, 12:08:44 pm
shwartzbewithyou
« Reply #6 on: May 09, 2006, 12:08:44 pm »
[ quote="vwmike" ] He must have done something to improve the aerodynamics considerably. [ /quote ]
Ya like a BIG FRICKIN' WING!!!
Reply #7May 09, 2006, 12:38:55 pm
BlackTieTD
  • 1512
« Reply #7 on: May 09, 2006, 12:38:55 pm »
downforce is nice - i'm sure he also has a very effective front airdam on that thing!!!
Reply #8May 09, 2006, 12:52:36 pm
  • 1156
    • Malone Tuning Ltd.
« Reply #8 on: May 09, 2006, 12:52:36 pm »
Someone on a forum mentioned that the Rabbit's windshield can implode at certain speed. Can anyone confirm that?
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #9May 09, 2006, 01:23:09 pm
Audi80
« Reply #9 on: May 09, 2006, 01:23:09 pm »
Hehe, this is Finnish ´77 Golf :D More discussion from vortex:
http://forums.vwvortex.com/zerothread?id=1672218
Shortly:
1.8 16v
81,5mm bore
wisecos
PO - metal H-beam conrods
Custom cams
Custom tubular exhaust manifold
Custom Intake
Holset HX40 60in/65ex
Hestec engine management
G60 tranny
Peloquin lsd diff
Wilwood brakes
Rollgage
2 - seat
Full - aviation spec fuel system
780cc/min injectors
564hp,60kg/m at crank on 1.9bar.
Reply #10May 09, 2006, 01:45:09 pm
VWRacer
  • 649
« Reply #10 on: May 09, 2006, 01:45:09 pm »
Holy Cow!  :shock:
You crazy Finns must have lots of time on your hands during those long, dark winters, eh?  :wink:
I just hope your cops don't catch him at 300+ kph. I hear you have some drakonian speeding penalties in your country.
Stan
Stan
C-Sports Racer
Reply #11May 10, 2006, 10:24:01 pm
Honda_Eater
  • 16
« Reply #11 on: May 10, 2006, 10:24:01 pm »
If i'm not mistaken, I believe that bunny is equipped with  megasquirt...
My brother showed me this vid about a year ago. I keep on watching it over and over and over again. Sounds evil! !!!!!!!!!!!!!!!
Reply #12May 12, 2006, 03:44:24 am
TDForNow
  • 131
« Reply #12 on: May 12, 2006, 03:44:24 am »
Malone:
I'm guessing it's at least a tad over 305 kliks !!
Major stones !!
He's probably got the center of 'is seat scooped out so he didn't 'afta sit on 'em !!!
'85 Quantum 1.6TD
'04 Passat 2.0 8vTDI
