Author Topic: Did I buy the right part??? Injector heat sheilds  (Read 4507 times)
May 03, 2006, 09:04:11 pm
masterbeavis
  • 88
« on: May 03, 2006, 09:04:11 pm »
I have an 81 rabbit p/u(diesel), build date 02/81.  I went to the stealership today, trying to buy the injector heat shields.  The computer showed the part as not being available, so the parts guy tried an '84.  The part showed up not as a heat shield, but as a washer.  The VW part number is 068-130-219.  Will this part work, or is it interchangeable, or did I just waste my money??
81 Caddy Diesel, 84 Jetta Diesel, 98 Jetta GLS, 99 Jetta GLX,, 95 Golf.
Reply #1May 04, 2006, 06:17:59 am
QuickTD
  • 1156
« Reply #1 on: May 04, 2006, 06:17:59 am »
The part number is correct. The heat shields look a lot like washers, but have some fine detail machined into them.
Reply #2May 04, 2006, 06:25:12 am
BlackTieTD
  • 1512
« Reply #2 on: May 04, 2006, 06:25:12 am »
bruce is right. i found that as well at the dealer, they call them washers.
Reply #3May 04, 2006, 12:14:57 pm
shwartzbewithyou
« Reply #3 on: May 04, 2006, 12:14:57 pm »
The first time I ever looked for them I was told they were called "crush washers", it was only here on this forum that i heard them called "heat shields".
Reply #4May 04, 2006, 01:20:25 pm
MacGyver
  • 245
Re: Did I buy the right part??? Injector heat sheilds
« Reply #4 on: May 04, 2006, 01:20:25 pm »
Quote from: masterbeavis
I'm sure you already know this, but make SURE you install them in the correct orientation.
As for heat shields vs crush washers, the soft copper alloy that TDI style 'washers' are made from makes them more of a crush washer.
Reply #5May 07, 2006, 12:05:26 am
masterbeavis
  • 88
« Reply #5 on: May 07, 2006, 12:05:26 am »
Quote from: shwartzbewithyou
In their computer it called them heat sheilds under '81, and under '84 they were listed as sealing washers.  In the VW service manual (79-81 jetta/rabbit) it also called them heat shields.  I picked them up on friday, they were in fact the right part.  Now all I have to do is figure out how to get one of the old ones out, it was caked in carbon :((
Reply #6May 07, 2006, 10:57:41 pm
fspGTD
  • 1529
« Reply #6 on: May 07, 2006, 10:57:41 pm »
Moved to general.  IDI engine is for performance enhancement discussion only.
Jake Russell
Reply #7May 08, 2006, 01:45:51 pm
shwartzbewithyou
« Reply #7 on: May 08, 2006, 01:45:51 pm »
Quote from: MacGyver
That would make sense.  I got that info off of the TDIclub website.  Should've known better.
