Author Topic: Help removing fuel sender unit 94 FrankenJetta  (Read 4371 times)
April 30, 2006, 06:07:49 pm
williamtaygan
  • 33
    • Arctic Vegwerks
« on: April 30, 2006, 06:07:49 pm »
1994 1.6Td Jetta.  Gas>Diesel conversion.  So I've got what appears to be a gas fuel tank.
Last winter I had massive air bubbles and fuel clogging somewhere before the fuel filter.  Fixed itself above freezing.
I'm guessing that there's sludge in the tank. I'd like to clean it out without dropping the tank.
I've got the fuel sender unit exposed and can spin the ring around but can't pry it off.
There's 3 ridges that are flush with the outside of the ring.  I tried lining one of those up with the little arrow on the sending unit, but it doesn't budge.  Can any of these 3 ridges line up, or only one?  I can't spin the ring all the way around, so I can only get at one of the flush ridges.  Maybe I'm completely off.
Help!
1981 1.6 NA Pickup
1982 1.6 NA Westfalia
1990 1.6 NA Jetta (not running)
1991 1.6 eco Jetta
1994 1.6 TD Jetta
Reply #1July 14, 2007, 06:37:24 pm
williamtaygan
  • 33
    • Arctic Vegwerks
Fuel pickup ring unscrews
« Reply #1 on: July 14, 2007, 06:37:24 pm »
It's not what it says in Bentley.  Instead of lining up the arrows and prying the ring off, it unscrews.  Cleaned out the tank in the vehicle with some rags and poured isopropyl over the pickup screen and it ran fine through the -25F last winter.
1981 1.6 NA Pickup
1991 1.6 eco Jetta
1994 1.6 TD Jetta
