Author Topic: Compresstion Test-1.6TD Not-Running-Unknown History  (Read 4450 times)
April 24, 2006, 04:46:44 pm
rich brennick
  • 25
« on: April 24, 2006, 04:46:44 pm »
Just picked this up; previous history is was running fine then lost power.  Sat for two seasons.
Initial timing check showed cam gear off one tooth. I re-timed.
Starter is marginal- won't spin as fast as it should.
Compression is approx 180# across the board- again, not turning fast.
Should I:
-Change the starter and hope for higher values?
-Put a bit of compressed air into #1 at TDC and listen for leaks (out the intake/ turbo?)
-Hank the head because I have bent valves?
- Or...?  Bueller?...Bueller?...
THX,
Rich
Reply #1April 24, 2006, 06:45:52 pm
dieselweasel
  • 312
« Reply #1 on: April 24, 2006, 06:45:52 pm »
First off I'd find out why it's cranking slowly...check the battery and cables.  Also bar the engine over by hand to check turning resistance.
Reply #2April 24, 2006, 07:29:29 pm
fspGTD
  • 1529
« Reply #2 on: April 24, 2006, 07:29:29 pm »
moved to troubleshooting section.  Not power enhancement related.
Jake Russell
Reply #3April 24, 2006, 07:55:39 pm
rich brennick
  • 25
« Reply #3 on: April 24, 2006, 07:55:39 pm »
10-4; Sorry for the mis-post.
