Author Topic: lets play "name that tool"!!!!!!!i got another one  (Read 14200 times)
April 23, 2006, 12:38:32 am
hillfolk'r
  • 1532
« on: April 23, 2006, 12:38:32 am »
what is this used for,,look closely :wink:  :wink:  :arrow:  :idea:
Throttle cables ftw
Reply #1April 23, 2006, 12:40:30 am
hillfolk'r
  • 1532
« Reply #1 on: April 23, 2006, 12:40:30 am »
the kitties foot is there for a reference :D
Throttle cables ftw
Reply #2April 23, 2006, 05:25:27 am
Patrick
  • 1034
« Reply #2 on: April 23, 2006, 05:25:27 am »
Just a wild guess, bushing puller/pusher for a turbo????????????
Reply #3April 23, 2006, 08:30:58 am
hillfolk'r
  • 1532
« Reply #3 on: April 23, 2006, 08:30:58 am »
no. hint: its made from a vw engine  part,look at those little sideways marks  down near the bottom,i did "machine" that part down,,,,note the 9/16 nut welded on the top, :D heehee this is fun!!
Throttle cables ftw
Reply #4April 23, 2006, 02:14:38 pm
« Reply #4 on: April 23, 2006, 02:14:38 pm »
sorta looks like the end of an intermediate shaft.  But what the hell do you use it for?  :D
84 Scirocco 8v
00 Camaro L36 M49
Reply #5April 23, 2006, 02:58:25 pm
« Reply #5 on: April 23, 2006, 02:58:25 pm »
that bears a striking resemblance to half my Chevy preluber.
Reply #6April 23, 2006, 04:24:12 pm
hillfolk'r
  • 1532
« Reply #6 on: April 23, 2006, 04:24:12 pm »
Quote from: 745 turbogreasel
you win a cookie!!!Its a "vw" preluber,now get out in the garage and build one!!!! :D  :twisted: buildin' stuff is fun!! use an old vacuum pump,,pull the seal out of the bottom,so the oil pump feed to the pump,can drain back easier,,and make sure you weld the nut real good,cause itll leak oil. i found out the hard way,basically plug that feed in the tool or you will have a gusher.then make sure you clean out the inside realgood before using it,no sense in dumping crap in your engine,we vw guys build stuff all the time how come i havent seen one of these yet?im kinda surprised :cry:
Throttle cables ftw
Reply #7April 23, 2006, 08:46:50 pm
hillfolk'r
  • 1532
i got another
« Reply #7 on: April 23, 2006, 08:46:50 pm »
here ya go,,and some more cat feet for reference,,,,
what is it??(im gonna runout of stuff soon,,,,, :cry:
Throttle cables ftw
Reply #8April 24, 2006, 12:28:13 am
« Reply #8 on: April 24, 2006, 12:28:13 am »
My D24T oil pump is crank driven....No prelubbin for me:(
Come to think of it, my vac pump is driven by the worlds heaviest pushrod.  Maybe I should go electric, but the pushrod thing has been very reliable.
Reply #9April 24, 2006, 04:26:37 am
SMOKEYDUB
  • 630
« Reply #9 on: April 24, 2006, 04:26:37 am »
that tool is for cleaning the threads on your glowplug holes in your cylinder head :D
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #10April 24, 2006, 04:04:37 pm
hillfolk'r
  • 1532
« Reply #10 on: April 24, 2006, 04:04:37 pm »
Quote from: SMOKEYDUB
YOU  R THE MAN!!!years ago,my 1.6td had a snapped off glow plug,number 3,it sucked,,,igot a big set,and welded a big ol' nut to the broken part, it was snapped off flush in the head!!i got it out,but i didnt know the thread size,and the threads were burred up a little,so i made a glowplug thread tap,,,use nuts and bolts as taps,if you grind a notch across them, zap themon a wire wheel,,granted it isnt as good as real thing,but it worked for what i needed,enjoy fabbing tools!!!!!dont buy it,make it,and learn!!!
Throttle cables ftw
Reply #11April 25, 2006, 09:18:17 pm
fspGTD
  • 1529
« Reply #11 on: April 25, 2006, 09:18:17 pm »
Very cool homemade tools!
I could really use a preluber like that for a splined shaft oil pump.
Jake Russell
Reply #12April 26, 2006, 09:03:15 pm
hillfolk'r
  • 1532
« Reply #12 on: April 26, 2006, 09:03:15 pm »
Quote from: fspGTD
sounds like its time to fabone up jake,,the next tool is actually  a "kit" i put together for myself,,ill try to get pics of the next item up tomorrow......... :D
Throttle cables ftw
Reply #13April 27, 2006, 09:21:02 pm
hillfolk'r
  • 1532
« Reply #13 on: April 27, 2006, 09:21:02 pm »
heres the next ones,,can be used as a "set" or individually,what are they??
Throttle cables ftw
Reply #14April 27, 2006, 10:56:07 pm
fspGTD
  • 1529
« Reply #14 on: April 27, 2006, 10:56:07 pm »
I know this one because I've read some of your other posts referring to it...  I'll let someone else try to guess instead of ruining the fun and mystery.   :wink:  Neat to see these pics, very creative!
Jake Russell
