Author Topic: Cooling Fan stays ON and will NOT shut off......??  (Read 4294 times)
April 21, 2006, 11:08:36 am
Katmandu
  • 47
« on: April 21, 2006, 11:08:36 am »
I just replaced the radiator in my 81 Diesel Rabbit and now the Cooling Fan on my stays running and will NOT shut off. It stays running LONG after what a "normal" cool down period would take.
 I finally pulled the plug (on back of the fan) after it was running for almost (10) minutes ??
 What do I need to check ??
Reply #1April 21, 2006, 12:17:13 pm
greggearhead
  • 153
« Reply #1 on: April 21, 2006, 12:17:13 pm »
When you installed the new radiator, did you replace the temperature switch as well?  Bleed your cooling system?
Caddy (TD Project), Caddy 1.6D, etc etc.
  Snow Performance Water-Methanol Injection
Reply #2April 21, 2006, 01:24:24 pm
A Guy
« Reply #2 on: April 21, 2006, 01:24:24 pm »
replace that sensor that you unplugged. $30 ish (Cdn)with new seal (metal crush washer).  Plug back in.  Bob's your uncle!  You should probably put in a new thermostat and o ring while your doing it.  Also hoses would be wise.
I say this 'cause I did my rad ...then I had to do hoses...then I had to do sensor...then I had to to Thermsat.  I could have saved a lot of time, money and cursing if I had odne it all at the same time.
Good luck
Out.
Reply #3April 21, 2006, 05:45:59 pm
Katmandu
  • 47
« Reply #3 on: April 21, 2006, 05:45:59 pm »
Quote from: A Guy
It was the fan I unplugged. Not a sensor.
 What sensor controls the fan and where is it located ??
Reply #4April 22, 2006, 04:16:46 am
Dennis Froelich
  • 258
« Reply #4 on: April 22, 2006, 04:16:46 am »
When you are standing in front of the car it is on the right side radiator tank. :)
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
