Author Topic: Broke down at last. Vacuum pump oil leak.  (Read 12562 times)
December 14, 2018, 04:03:37 pm
smutts
  • 720
    ClackClackClackClackClack
« on: December 14, 2018, 04:03:37 pm »
If you see your vacuum pump (on the end of the camshaft) leaking oil, that oil is dripping unseen onto a tiny 3" long coolant pipe hidden beneath. The oil will rot the coolant pipe, and it will pop. Pissing all your expensive G12 all over your gearbox speed sensor, which will also likely go wrong...(no speedo, wobbly fuel gauge, disco fuel light and irritating low fuel bongs will follow).
The Seat (spanish take on a MK4 Golf with VW bits)  has a wonderful sense of timing. Drove all round the Uk last month. Devon to Norwich, Lincoln, Chesterfield, Macclesfield, Peak District. Returning home on the motorway, just got dark, On comes the flashing red coolant light with it's associated bongs, 300 yards from the Gloucester Services slip (One of the better places to stop to).
With a lot of swearing, i managed to get a piece of 8mm fuel hose in as a stopgap and get  home. But the hose spring clips are devils.
Looking up the part number for that hose, 1J0122447EP, it is an assembly of about 9 bits, 8 of which you won't need, for the bargain price of £100 ish. VW must sell loads....not! So off to the scrap yard for some suitable replacement 8mm? coolant hose.
Fuel hose is oil proof, but will harden and crack with heat.
The vacuum pump oil seal is part no "038145345" , if the pump is leaking from it's two halves, you need a 76mmx2.5mm viton "O" ring, google will show you what to do. Mine is now nice and oil tight. 8)
ASV, 218k miles & counting.
« Last Edit: December 14, 2018, 04:06:04 pm by smutts »
Reply #1January 13, 2019, 06:43:48 am
Warnertaure
  • 7
Broke down at last Vacuum pump oil leak
« Reply #1 on: January 13, 2019, 06:43:48 am »
An ALH shouldnt have a fuel pump at the tank, the injection pump does that work. Have you checked the fuel solenoid on the injection pump for power?
Reply #2February 02, 2019, 08:14:46 am
smutts
  • 720
Re: Broke down at last. Vacuum pump oil leak.
« Reply #2 on: February 02, 2019, 08:14:46 am »
Reply #3February 02, 2019, 07:52:41 pm
« Reply #3 on: February 02, 2019, 07:52:41 pm »
Warnertaure seems to make posts that are almost on topic or sensible but not really.  I've been wondering if they are a young AI that is lonely and wanting to enter into conversations and learn to communicate with humans.
Reply #4February 03, 2019, 12:40:34 pm
« Reply #4 on: February 03, 2019, 12:40:34 pm »
I have been asking the moderator to delete all these new accounts.  Like you say, someone is fishing for something and we can only offer diesel dipped or fried fish.
Those members offering the fake passports were terrible.  Hope that activity has ceased.  I wasn't sure if they were trying to target the conversations with the most posts or what.  Sometimes they brought up threads that were long since packed away.
