Author Topic: Rabbit 1.5 & 1.6 injection parts compatible?  (Read 2089 times)
August 13, 2018, 06:52:23 am
Gnarlodious
  • 25
« on: August 13, 2018, 06:52:23 am »
Will the injection system (pump, pressure tubes and injectors) from a later 1.6 diesel fit on the 1.5 engine, and work? Is there a page somewhere that tells what engine parts are compatible?
’83 Vanagon AAZ
Reply #1August 13, 2018, 08:59:36 am
Re: Rabbit 1.5 & 1.6 injection parts compatible?
« Reply #1 on: August 13, 2018, 08:59:36 am »
Injection pump, lines, and injectors should work fine.  I'm not aware of a page that outlines the engine differences.  My experience with 1.5's is fairly limited and not recent.  Off the top of my head I believe the pistons, rods, and crank are different along with the intermediate shaft.  The head bolts are also 11mm vs. 12mm although the earliest 1.6's used the 11mm bolts.
Reply #2August 13, 2018, 04:21:29 pm
Gnarlodious
  • 25
« Reply #2 on: August 13, 2018, 04:21:29 pm »
That helps, thanks.
’83 Vanagon AAZ
