Diesel Swaps
AAZ going in to a 914...
Pages:
Topic: AAZ going in to a 914... (Read 17137 times)
Reply #15
July 25, 2018, 02:14:43 pm
Patrick
Re: AAZ going in to a 914...
Reply #15 on:
July 25, 2018, 02:14:43 pm »
That`s what I thought.
Reply #16
August 09, 2018, 04:32:59 am
Patrick
Reply #16 on:
August 09, 2018, 04:32:59 am »
Engine is bolted in, mk2 mount on the back side of the engine, stock transmission mounts on the Porsche 901 trans. Might have to add a 4th mount on the left side of the engine (front? at the power steering pump that I don't need) We'll see after it's fired up. Rad mount is the next issue. Car once had a rad in the front to cool a dodge 360. pipes are still there... going to try to put a smaller rad in the engine bay so I can close the front trunk back up into a sealed dry compartment. Currently has the front of the car swiss cheesed and a big hole in a fender well to let the air flow back out.
Do pictures have to be posted elsewhere and then linked??
Reply #17
August 09, 2018, 05:50:28 pm
Reply #17 on:
August 09, 2018, 05:50:28 pm »
Yes, I believe images need to be hosted elsewhere. I've been using Imgur lately since the photobucket debacle.
Reply #18
September 01, 2018, 04:16:55 am
Patrick
Reply #18 on:
September 01, 2018, 04:16:55 am »
Honda civic rad in the engine compartment. Not sure if it will be enough. Should be according to the adaptor kit company but natural airflow won't be great. Probably have to run the fan a lot more than the same engine in the jetta. Lower mk2 rad hose is a direct fit, had to cut and paste on the upper. Custom part for the heater hose outlet on the back of the head, going to direct connect without a heater core for now. Progress is slow when you have a day job!
Reply #19
September 01, 2018, 11:00:42 am
Reply #19 on:
September 01, 2018, 11:00:42 am »
You might consider an mTDI. The higher thermal efficiency of the direct injection dumps way less heat into the coolant (~1/2) for the same power.
Reply #20
September 02, 2018, 05:52:20 am
Patrick
Reply #20 on:
September 02, 2018, 05:52:20 am »
Down the road.... but for now using what I have.
Reply #21
September 02, 2018, 06:55:23 am
Reply #21 on:
September 02, 2018, 06:55:23 am »
I can understand using what you have. I just mentioned it to keep in mind if you have issues with radiator sizing. The TDI can use a much smaller radiator due to the drastically reduced heat load on the cooling system.
Reply #22
September 05, 2018, 02:43:02 am
Patrick
Reply #22 on:
September 05, 2018, 02:43:02 am »
Next issue: fuel return line on the 914 tank has been messed with.... If I hook as is I'll have the fuel returning to the bottom of the tank. I assume it should be dumping at the top?? or is it an issue?
Reply #23
September 05, 2018, 07:54:47 pm
Moderator
4552
Reply #23 on:
September 05, 2018, 07:54:47 pm »
I don't see it as an issue, as long as it returns that is all I would worry about.
Reply #24
September 08, 2018, 02:12:01 pm
Patrick
Reply #24 on:
September 08, 2018, 02:12:01 pm »
Close enough I had it fired up today... didn't run long enough to suck fuel from the tank through the whole system. Quit for today. Tomorrow put the wheels back on and sit the back end on the ground, fill the tank to the top. Gravity should push fuel as far as the filter if I take the bleed screw out the way everything sits. Should be an easy fire after that... We'll see.
Reply #25
September 08, 2018, 05:16:18 pm
Reply #25 on:
September 08, 2018, 05:16:18 pm »
I swap a spare IN bolt and banjo onto the pump OUT bolt location and then pull a vacuum on it. It pulls fuel from the tank, primes the filter, and primes the pump completely. Easy peasy. I then have the metal lines tight at the pump but loose at the injectors and crank the engine over until there are some spurts of diesel at a injectors. Tighten them down and it will fire right off and run well if everything else was done correctly.
Reply #26
September 08, 2018, 07:36:04 pm
Moderator
4552
Reply #26 on:
September 08, 2018, 07:36:04 pm »
I agree with Libby, Pull fuel through the system then try it with loosened injector nuts. If fuel shows, even on just a couple then tighten them all and try to start it.
I think your trouble was there is only so much fuel in the pump and it generally is not enough to prime a line from the tank especially if the filter has some air in it.
Reply #27
September 09, 2018, 05:03:20 pm
Patrick
Reply #27 on:
September 09, 2018, 05:03:20 pm »
IT'S ALIVE!!
https://youtu.be/6BwvBVNTJbQ
Reply #28
September 09, 2018, 09:12:05 pm
Moderator
4552
Reply #28 on:
September 09, 2018, 09:12:05 pm »
Nice coal, turn down the fuel screw a tad. Don't want to draw unnecessary attention to what might be a non standard power plant in there.
Reply #29
September 10, 2018, 02:34:36 am
Patrick
Reply #29 on:
September 10, 2018, 02:34:36 am »
Don't remember the coal being quite so bad with this engine in the Jetta. fuel going down, and maybe the smaller turbo back on too. maybe a little slow to spool.
Non standard engine isn't really an issue... car is old enough that emissions isn't a problem here. And as for the insurance company, it's still a four cylinder....
VW Oil pressure switch in the back of the head running the porsche idiot light works fine. Did have an oil leak and figured out the sensor wasn't screwed in tight enough... had it out to screw a gauge in and do a pressure check.. Early VW water outlet for head with a screw in sensor hooked to the Porsche temp gauge seems to work fine. Ran it for 20 minutes or so and it got to about 165 according to my infrared temp gun, showed just over 1/2 on gauge. Next step is garage cleanup, put the trunk lid back on, back it outside for a bath, and take it for a drive. Then to the muffler shop. Probably leave it straight through for now, may wind up with a muffler though. This engine seems louder than the other one I'm running, partly because the timing is advanced a little more on this one I think.
Pages:
Diesel Swaps
