Author Topic: 150hp+ aaz build  (Read 3217 times)
February 05, 2018, 02:27:23 pm
BenH421
  • 2
150hp+ aaz build
« on: February 05, 2018, 02:27:23 pm »
I've currently got a standard Aaz engine in my Passat B4 wagon, k03 turbo, 1.6td boost pin and some slight fuel adjustments.
I'm looking for some advice on the possibility of producing at least 150hp or even more out of my engine, I'm happy to upgrade the turbo but unsure on the route I should take
Any advice would be appreciated, a link to someone's build thread with a reliable setup producing good numbers in which I could follow would also be of great help
Cheers
Reply #1February 05, 2018, 03:45:24 pm
RunninWild
  • 609
Re: 150hp+ aaz build
« Reply #1 on: February 05, 2018, 03:45:24 pm »
Arp head/main studs, Giles pump and a holset he220wg turbo
Reply #2February 06, 2018, 05:36:47 am
BenH421
  • 2
« Reply #2 on: February 06, 2018, 05:36:47 am »
Don't suppose you could post over a link to purchase a he220wg turbo, been looking around and haven't had much luck, I'm in the uk, they are probably more readily available within the us I guess
Reply #3February 06, 2018, 09:16:36 am
RunninWild
  • 609
« Reply #3 on: February 06, 2018, 09:16:36 am »
Contact alcaid on the forum. Hes usually the guy that people get them from. Its not bolt on though. Itll take some work to make it fit. Do some research. There's a sticky i made at the top of the page that has a lot of the information youll need to mount one.
