Author Topic: FS NOS 1.6TD pump  (Read 5176 times)
January 29, 2018, 09:35:49 am
FS NOS 1.6TD pump
« on: January 29, 2018, 09:35:49 am »
SOLD
This pump has never had diesel run through it. Due to it's age, I removed the timing covers to make sure that the insides weren't gummed up from sitting. The insides showed no signs of corrosion and actually still had calibration fluid in it. There was slight gumming or staining from the calibration fluid. I tried moving the advance piston and it does move but it feels a bit stiff. It may just be where the pump is in it's rotation though. The pump is missing the stop solenoid and associated pieces and also a spring and some clips from the advance lever. I'm not able to turn the driveshaft over because I don't have the correct pulley.
Due to the age of the pump, it's possible that it will need to be resealed. I did replace both advance cover seals.
As best I can tell, this is off an Audi 80. Is bolt on for a VW 1.6TD with the exception of the throttle cable. All you would need to do is swap the ball joint from your pump to this one and it would be bolt on.
Asking $300 US
0460494237
068130081K
« Last Edit: April 02, 2018, 12:45:17 am by burn_your_money »
Reply #1March 04, 2018, 08:16:39 pm
Re: FS NOS 1.6TD pump
« Reply #1 on: March 04, 2018, 08:16:39 pm »
Make an offer, I'd like to see this installed on someones engine.
Reply #2March 05, 2018, 07:46:52 pm
« Reply #2 on: March 05, 2018, 07:46:52 pm »
Hmm, time for a PM as I am gathering parts for the 1.6 NA to Turbo conversion on the new/old Caddy.
Reply #3March 22, 2018, 09:57:23 am
« Reply #3 on: March 22, 2018, 09:57:23 am »
Still for sale
