Author Topic: 1.6 td alternator wiring swap  (Read 4577 times)
January 17, 2018, 08:07:28 pm
bpcaddy
  • 30
« on: January 17, 2018, 08:07:28 pm »
Hate to post this but all the pictures are not on the threads! Very hard to understand what they are saying.
I got a 1992/1991 probably eco 1.6 td in my mk1.
Has 2 red wires going to a bolt. And the blue exciter wire. I added ground from casing to body of truck and replaced regulator/brushes and cleaned up battery grounds.
Nothing! No change in voltage while car running.
Does wiring sound good?
Either replace diode or entire alternator or seriously check the wiring.
Thanks
Reply #1January 17, 2018, 08:08:54 pm
Tmarkle
  • 153
Re: 1.6 td alternator wiring swap
« Reply #1 on: January 17, 2018, 08:08:54 pm »
Does it start charging if you really rev it up? If so it’s an exciter wire issue.
1985 Jetta 1.6 NA, Project
1981 Rabbit 1.5 diesel SOLD
1980 Dasher, also a project
1993 Passat GLX VR6 (daily driver)
1992 Toyota Pickup, 350 V8 swapped
1997 Jetta TDI, engine donor for a diesel powered Toyota!
1986 Toyota Custom Cab
Reply #2January 17, 2018, 08:13:16 pm
bpcaddy
  • 30
« Reply #2 on: January 17, 2018, 08:13:16 pm »
Thanks Tmarkle. No change in voltage.
Autozone alternator checker says battery to low to check alternator. But voltage doesn't change at all.
Reply #3January 17, 2018, 08:22:58 pm
bpcaddy
  • 30
« Reply #3 on: January 17, 2018, 08:22:58 pm »
Also dummyI got on dash went out after regulator replacement
Reply #4January 17, 2018, 09:24:59 pm
« Reply #4 on: January 17, 2018, 09:24:59 pm »
The Bentley has a procedure for doing a series of tests on the alternator wiring and what the typical voltage is when running.  Do you have that book for reference?
Reply #5January 18, 2018, 07:30:27 am
srgtlord
  • 797
« Reply #5 on: January 18, 2018, 07:30:27 am »
If I remember correctly the alternator on the eco engine should be putting out between 13.5-14 volts to be considered a "good" alternator. That being said you should also have 12v coming from the blue wire
Reply #6January 20, 2018, 01:47:46 pm
bpcaddy
  • 30
« Reply #6 on: January 20, 2018, 01:47:46 pm »
I don't have Bently but I took alternator to a tester and I watched them hook it up and everything was bad. Rusty from Germany.
I could Swap my bracket from my 1981 1.6 na. But to get the bracket off the 1992 td there are 2 bolts behind the bracket and under the pump so I would have to take entire pump off to get to those bolts. Unless it's like my 81 na where the 2 bolts are in the water pump housing and I just take the water pump housing off ...?
I don't have tools to time pump and had to Limp to shop with untimed pump last time I took belt/pump off.
None of my local parts store can get the alternator either :/
Reply #7January 20, 2018, 02:07:31 pm
bpcaddy
  • 30
« Reply #7 on: January 20, 2018, 02:07:31 pm »
Many threads saying just get swivel for one hidden bolt and one guy says heat up and bend wrench for the other. Ok!
Reply #8January 20, 2018, 10:29:56 pm
bpcaddy
  • 30
« Reply #8 on: January 20, 2018, 10:29:56 pm »
Swapped the 1981 1.6 na bracket. Works.
To get the bolts out of the 1.6 td 1992 alternator bracket use swivel socket and extension for both. Swivel socket is rotates like 60 degrees and still works.
Reply #9January 21, 2018, 05:21:30 pm
  • 2931
« Reply #9 on: January 21, 2018, 05:21:30 pm »
So you don't have a local alternator/starter rebuilder?
Reply #10January 21, 2018, 05:45:39 pm
« Reply #10 on: January 21, 2018, 05:45:39 pm »
Lotta local shops are gone now, even in bigger towns.
I'd pop for a Bosch reman and get some penetrating oil onto the pulley nut (you're gonna need that pulley and fan stuff).
