Author Topic: RIP The Black Lady  (Read 4055 times)
November 08, 2017, 01:30:41 pm
Norsker
  • 24
RIP The Black Lady
« on: November 08, 2017, 01:30:41 pm »
Welp. The MK2 is dead.
Driving along everything is fine, next thing i know im at 3000 rpm and my engine goes kaboom.
Threw a rod directly out of the front of the block... And the back.
Shouldn't take more than a weekend to get a new engine in it?
Is the SB/RA engines more "reliable" or stronger built than the JR engine i had in?
Reply #1November 08, 2017, 01:53:50 pm
Re: RIP The Black Lady
« Reply #1 on: November 08, 2017, 01:53:50 pm »
Recently rebuilt head?   Keepers all spotlessly cleaned?  Or Older head that just got tired of 3000 RPM's?
Reply #2November 08, 2017, 03:04:55 pm
« Reply #2 on: November 08, 2017, 03:04:55 pm »
A healthy 1.6 should do 3K all day long, every day.
How many miles on the odo? When were the IM shaft bearings last changed?
A ready-to-go engine should be an easy weekend swap.
Reply #3November 13, 2017, 05:40:28 am
Norsker
  • 24
« Reply #3 on: November 13, 2017, 05:40:28 am »
Well it fired out both sides of the bottom of the engine, don't know what the part is called in english but i think it's the conrod bearing which i could see the remains of, from the hole in the engine.
Was running a 1.9 AAZ head.
Found an SB engine with 220k's on the clock. Hope it fires up, been sitting since spring.
Reply #4November 13, 2017, 06:02:27 am
Norsker
  • 24
« Reply #4 on: November 13, 2017, 06:02:27 am »
Oh and the engine still cranks and runs.
3 cylinder 1.2TD  ;D
Reply #5November 13, 2017, 09:26:50 am
« Reply #5 on: November 13, 2017, 09:26:50 am »
3 cylinder 1.2TD  ;D
25% less pumping losses.
Reply #6November 14, 2017, 12:51:30 am
Norsker
  • 24
« Reply #6 on: November 14, 2017, 12:51:30 am »
Haha yeah. I just hope the replacement engine i got is good.
Cranks just fine, no abnormal resistance in turning over.
The wiring harness is not the same though, as this K14 Turbo has watercooling :o
Gotta swap that out then :c Does any of you know if theres a difference in the fusebox?
Reply #7November 18, 2017, 01:37:43 am
Norsker
  • 24
« Reply #7 on: November 18, 2017, 01:37:43 am »
IT LIVES!
The new engine sounds 10x healthier than the old one.
HOWEVER
The fuel lines look like a spa bath. There's more air than fuel in the lines. What do?
Reply #8November 18, 2017, 04:05:00 pm
« Reply #8 on: November 18, 2017, 04:05:00 pm »
I'd run it directly from a clean bottle of fuel. Clear lines in and out of the IP to the bottle.  After 5-10 min, if there are bubbles in the return line, the front seal is likely leaking.
Reply #9November 26, 2017, 08:14:50 am
Norsker
  • 24
« Reply #9 on: November 26, 2017, 08:14:50 am »
We tried a lot of stuff, replaced seals, tried a water bottle, and the bubbles went away!
But.
If we floor it, you can hear it missing on 1 cylinder.
We suspect an injector, but after working a whole weekend on it and doing the "expensive" labor, i'm gonna send it to a shop now :)
Reply #10November 26, 2017, 10:36:00 am
« Reply #10 on: November 26, 2017, 10:36:00 am »
Wouldn't running it the way it is with a good dose of injector cleaning fluid in the tank be your next "expensive" fix?
Shop labor = Highway robbery to those who are do it themselfers.
Reply #11December 16, 2017, 07:07:27 am
Norsker
  • 24
« Reply #11 on: December 16, 2017, 07:07:27 am »
Well my only local diesel shop fixed it for 100 bucks :)
Hooked everything up correctly that we missed (glow plugs, cold start, so on...)
Runs great now! However the clutch starts to slip if i floor it at around 110km/h in 5th or 4th :(
