Is there a way to get rid of the vacuum pump?
Pages:
Topic: Is there a way to get rid of the vacuum pump? (Read 13482 times)
Reply #15
November 23, 2017, 09:50:20 am
Tmarkle
Re: Is there a way to get rid of the vacuum pump?
Reply #15 on:
November 23, 2017, 09:50:20 am »
Here’s how the 1.5 in my rabbit is set up without a vacuum pump. Brakes are a pain without it though.
1985 Jetta 1.6 NA, Project
1981 Rabbit 1.5 diesel SOLD
1980 Dasher, also a project
1993 Passat GLX VR6 (daily driver)
1992 Toyota Pickup, 350 V8 swapped
1997 Jetta TDI, engine donor for a diesel powered Toyota!
1986 Toyota Custom Cab
Reply #16
January 26, 2018, 12:39:46 pm
Jetmugg
Reply #16 on:
January 26, 2018, 12:39:46 pm »
Is there anything to support the top of the gear/oil pump shaft from deflecting?
Steve.
Reply #17
August 16, 2018, 05:49:44 am
cm198965
Newbie
Reply #17 on:
August 16, 2018, 05:49:44 am »
Can you add a 12 v electric pump to replace the mechanical one?
Sent from my SM-N950U using Tapatalk
Reply #18
August 16, 2018, 07:37:05 am
Reply #18 on:
August 16, 2018, 07:37:05 am »
Quote from: Jetmugg on January 26, 2018, 12:39:46 pm
Steve.
The oil pump shaft has one of the gears as part of it and it is a very close tolerance machined fit where it runs through the oil pump case. There is another oil pump shaft bushing that it pressure oiled near the top of the shaft.
Reply #19
June 15, 2019, 09:24:01 am
30dodgeboy
Newbie
Reply #19 on:
June 15, 2019, 09:24:01 am »
I have some marine 1.6D parts, shoot me a PM
Pages:
