Author Topic: A1 turbo kit into an A2  (Read 2296 times)
April 14, 2006, 04:37:27 pm
mainer
  • 126
« on: April 14, 2006, 04:37:27 pm »
I've got a Turbo kit for an A1, the turbo is mounted at the end of the manifold not in the middle like the A2's also the DP has a nice bend in it not like the A2's. So is there any way I can adapt it to fit? I can get a new DP made up no problem, but what I'm worried about is the the motor mount and the turbo. I belive that A2's had the turbo mounted in the center of the manifold not on the passenger side like the A1's.
Any way I can get it in there with out any problems? Thanks Cooper
_________________
Loratab Rehab Forum
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #1April 14, 2006, 05:31:19 pm
DieselsRcool
  • 152
« Reply #1 on: April 14, 2006, 05:31:19 pm »
The A1s and A2s use the same exh manifolds. It sounds like you have an exh manifold from a fox/Quantum installation. This manifold is unusable for the Rabbits. The intake manifold, pump and turbo can be used but not the piping.
