Author Topic: WTB: VW 1.6 diesel turbo hose  (Read 5197 times)
August 03, 2017, 07:40:55 am
dailydubber
  • 18
« on: August 03, 2017, 07:40:55 am »
I'm looking for the hose that comes from the turbo compressor outlet and into the intake manifold. I have a k24 Turbo. My zip code is 21666
Sent from my HTC6545LVW using Tapatalk
Reply #1August 03, 2017, 10:02:50 am
RockOcean
  • 139
Re: WTB: VW 1.6 diesel turbo hose
« Reply #1 on: August 03, 2017, 10:02:50 am »
I have one from an AAZ 1.9L Turbo Diesel not sure if it's the same? The part number is 1H0 129 627 AB.
Sent from my SM-G925V using Tapatalk
Reply #2August 03, 2017, 10:22:56 am
dailydubber
  • 18
« Reply #2 on: August 03, 2017, 10:22:56 am »
I'm actually looking for the one
 coming out of the turbo and not going in the turbo like the one on this link:
http://www.mk1autohaus.com/Lifetime-Silicone-16L-TD-19L-Aaz-Turbo-Diesel--Intake-Boost-Hose_p_6518.html
Reply #3August 04, 2017, 04:32:32 am
« Reply #3 on: August 04, 2017, 04:32:32 am »
if you are not worried about it looking original you can use a 2" silicone elbow, i have in the past. black silicone looks decent too.
Reply #4August 04, 2017, 02:08:13 pm
dailydubber
  • 18
« Reply #4 on: August 04, 2017, 02:08:13 pm »
I've tried putting a 90 degree elbow like you mentioned but it is getting kinked. I've also adjusted the compressor housing to lessen the kink but it didn't work. So I figured the original has special curves to prevent any kinks.
Reply #5August 07, 2017, 04:40:07 am
« Reply #5 on: August 07, 2017, 04:40:07 am »
mine was on an aaz which has a little bit different of an angle on the inlet hose so maybe i had better luck because of that.
