k24 - service/swap options
Topic: k24 - service/swap options (Read 8092 times)
July 11, 2017, 01:59:16 pm
oblique
Diesel while you can.
July 11, 2017, 01:59:16 pm »
So im pretty sure I have a sticky wastegate but while I have it out I want to service the rest of the turbo. problem is local shops either wont touch it because they cant replace the wastegate and others make no guarantees that theyll be able to service it.
Does anyone know a shop thats good with these? So far nothting in the Toronto area, only XSboost in Ohio is saying theyve had luck.
Alternatively, is there a relatively low-cost bolt-on replacement option? I dont want to fab anything and would prefer not to run external boost regulator, if possible. If I have to get small things like oil lines, etc. to make something work then thats ok.
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
July 12, 2017, 06:37:06 am
oblique
Re: k24 - service/swap options
July 12, 2017, 06:37:06 am »
I have a lead on a T3. Is it a direct bolt on? Are both oil lines different?
90 1.6TD Jetta
79 1.6Na Rabbit
July 12, 2017, 08:24:24 am
July 12, 2017, 08:24:24 am »
yes, the t3 bolts directly in place of a k24, down, pipe, oil feed, and oil drain are all the same. The t3 also has a non serviceable wg, but the t3 wastegate is much more reliable as long as it doesn't rust away.
July 12, 2017, 08:49:06 am
oblique
July 12, 2017, 08:49:06 am »
Is there any way to tell the condition of the wastegate at point of purchase? Can a rebuilder clean/service a non functional wastegate? I got quoted $500CDN by a local shop but was told to bring the turbo in before he could say for sure. Kind of defeats the purpose as I'm shopping for a turbo that I know can be rebuilt.
What gaskets should I account for a turbo swap?
-turbo to manifold gasket
-turbo to iron downpipe
-oil line gaskets (supply and drain)
some pics of what in there now:
http://imgur.com/a/pg17f
Last Edit: July 12, 2017, 09:32:56 am by oblique
90 1.6TD Jetta
79 1.6Na Rabbit
July 12, 2017, 12:32:45 pm
July 12, 2017, 12:32:45 pm »
To be specific the original T3 that came on VW diesels is a direct swap. There's a gazillion varieties of T3 turbo out there most of which are not a direct swap nor will they function properly on your engine.
There's also K14 and T2 turbos around with the VW mounting flange. They're a more suitable turbo for general driving than the stock K24/T3.
Sent from my LG-H873 using Tapatalk
July 12, 2017, 12:43:25 pm
July 12, 2017, 12:43:25 pm »
k14 has the same serviceability and sticky wg issue.
id say on a t3, if the wg can is intact 99% chance that it functions fine.
July 12, 2017, 12:43:49 pm
July 12, 2017, 12:43:49 pm »
also, though i totally agree the k14 and t2 are much better turbos for stockish engines.
July 12, 2017, 02:05:25 pm
oblique
July 12, 2017, 02:05:25 pm »
Any idea which cars had T2 turbos that will fit an MF 1.6TD? How much modification is required? I assume custom downpipes and oil lines at a minimum?
90 1.6TD Jetta
79 1.6Na Rabbit
July 12, 2017, 05:04:51 pm
July 12, 2017, 05:04:51 pm »
The K14 or T2 could be found on 1.6 Eco diesels and on AAZs. I believe they're a direct swap.
July 14, 2017, 12:20:39 pm
July 14, 2017, 12:20:39 pm »
t2 might have different flanges, but k14 has the same flanges, and oil feed line, how ever the oil drain line is different, but if you have a complete 1.6td oil drain, and the k14 oil drain you can combine the 2 very easily and make it work. I did the reverse of that to put a t3 on my aaz.
July 17, 2017, 10:08:13 am
oblique
July 17, 2017, 10:08:13 am »
Picked up a T3 this weekend with all lines and manifolds from a retired German machinist. Spins free and looks clean - hopefully I can use as-is. Will post pics later.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #11
July 17, 2017, 05:57:49 pm
oblique
Reply #11 on:
July 17, 2017, 05:57:49 pm »
Photos of the body and the shaft play. Im pushing side to side as hard as I can while keeping the camera steady.
Last Edit: July 18, 2017, 04:39:48 am by oblique
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #12
July 18, 2017, 04:40:16 am
oblique
Reply #12 on:
July 18, 2017, 04:40:16 am »
Any comments on shaft play? Can I use as-is?
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #13
July 18, 2017, 10:02:09 am
Reply #13 on:
July 18, 2017, 10:02:09 am »
Does the wheel contact the housing? If not you're fine.
Is there any axial (in and out) play? If not you're fine.
Reply #14
July 19, 2017, 05:00:30 am
Reply #14 on:
July 19, 2017, 05:00:30 am »
what he said ^^^^
if not, t3 rebuild kits are cheap, and yours looks like it was balanced in separate pieces and not as a unit so you could rebuild it yourself, and install a 360 degree thrust bearing for more durability and faster spool up. Although on the durability stand point the t3 is pretty bullet proof.
