Author Topic: New turbo cartridge acceptable play  (Read 5455 times)
June 13, 2017, 06:59:27 pm
Ian0391
  • 119
« on: June 13, 2017, 06:59:27 pm »
So long story short, I was desperate for a k14 turbo so I bought a cartridge from a dealer who is not known for quality. The turbo cartridge has about .030" play axially along the shaft, pulling in and out on the wheels. I contacted them and they responded that the manufacturer assured them that is more than acceptable. It has enough play though that the compressor wheel can touch the housing. Does anyone know what's acceptable? Are there any numbers out there? I checked through my Bentley manual but found nothing.
Sent from my SM-G920W8 using Tapatalk
Reply #1June 13, 2017, 08:19:00 pm
Re: New turbo cartridge acceptable play
« Reply #1 on: June 13, 2017, 08:19:00 pm »
If it can touch the housing it is most definitely NOT acceptable.
Reply #2June 13, 2017, 08:44:11 pm
Ian0391
  • 119
« Reply #2 on: June 13, 2017, 08:44:11 pm »
Yeah that's what I figured. Do you know what amount is acceptable?
Reply #3June 13, 2017, 09:50:58 pm
« Reply #3 on: June 13, 2017, 09:50:58 pm »
Axial play should barely be perceptible.  I haven't measured it but you can just barely feel it when you push one way and then the other.
Reply #4June 14, 2017, 04:45:14 am
Ian0391
  • 119
« Reply #4 on: June 14, 2017, 04:45:14 am »
That's what I always thought. It is definitely very perceptible, visually and by feel. I was actually suprised when I measured it that the numbers were so small. They supplier is saying that those numbers are fine though which baffles me.
Reply #5June 14, 2017, 10:13:26 am
« Reply #5 on: June 14, 2017, 10:13:26 am »
Someone who sells garbage knock-off turbo cartridges probably isn't all that concerned about relaying accurate specs.
Reply #6June 14, 2017, 01:53:17 pm
Ian0391
  • 119
« Reply #6 on: June 14, 2017, 01:53:17 pm »
Yeah that's more or less what I figured. I'm definitely sending it back. Do you know where I can find a k14 new, used or rebuilt? I haven't had much luck. All I cam find is knock offs also of questionable quality.
Reply #7June 14, 2017, 02:35:56 pm
« Reply #7 on: June 14, 2017, 02:35:56 pm »
I've got a couple of Eco k14s that need servicing. If you want one of these (or from others), or keep the one you have, you could get service from xsboost.
PM me if you're interested.
« Last Edit: June 14, 2017, 02:48:03 pm by TylerDurden »
Reply #8June 15, 2017, 02:33:00 pm
Ian0391
  • 119
« Reply #8 on: June 15, 2017, 02:33:00 pm »
I sent you a pm. According to the vendor the  .030 of play will be taken up by the oil the bearing runs on. I'm not sure if he thinks I'm running 100w oil or what but that seems entirely rediculous to me.
Reply #9June 15, 2017, 03:01:30 pm
« Reply #9 on: June 15, 2017, 03:01:30 pm »
Radial play will be taken up by oil pressure. Axial play will not.
Sent from my LG-H873 using Tapatalk
Reply #10June 15, 2017, 03:10:56 pm
Ian0391
  • 119
« Reply #10 on: June 15, 2017, 03:10:56 pm »
So I just by chance realized why there is so much play axialy, the compressor nut was just finger tight. I don't know how I didn't realize this sooner. Goes to show the excellent build quality.
Reply #11June 16, 2017, 07:16:05 am
« Reply #11 on: June 16, 2017, 07:16:05 am »
Update:
Looks like all I have right now are a couple of T3s that need seals. I thought they were k14s, but I musta sold those. My bad.
Reply #12June 16, 2017, 11:13:13 am
Ian0391
  • 119
« Reply #12 on: June 16, 2017, 11:13:13 am »
It'd all good, unfortunately only a k14 will fit where I'm putting it. I think I might just rebuild this cartridge myself.
Reply #13June 17, 2017, 10:09:09 am
« Reply #13 on: June 17, 2017, 10:09:09 am »
If the nut is loose enough that the wheel has moved on the shaft it needs to be sent out for balancing. Considering it was shipped loose I'd wager it hasn't been balanced properly at all yet. Remember these spin at 100,000+ RPM, having it balanced is critical.
Reply #14June 17, 2017, 11:21:43 am
Ian0391
  • 119
« Reply #14 on: June 17, 2017, 11:21:43 am »
I always thought the compressor wheel was balanced seperately from the turbine and shaft so the compressor wheels could be swapped?
